Intermittent problem starting - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 05-04-2010, 06:04 PM Thread Starter
<-- it's like that
I've had an issue with my truck not wanting to start. It doesn't happen all the time, but it's becoming a problem since I'm about to drive to Houston next week towing a trailer.
I get a code P1277 (Cylinder #7 Open circuit, open injector, failed IDM). This is the only code I get (does NOT set a P1316), and only pops up under a KOEO test or an Injector Buzz test. It does not pop up on it's own, does not set a check engine light, and doesn't come up under any other tests. With the engine fully warm, cylinder #7 shows 0% change in rotational velocity. All other cylinders are normal range.
The problems I have is my truck will randomly not start. Another issue is that sometimes it does start, but acts like it's only running on half the cylinders. When it does this, I'll kill the engine, and restart over and over again until it runs correctly (it will not clear up on it's own, I have to recrank the truck to fix the problem). When it acts like it runs on only half the cylinders, it does not trigger any codes, and it smokes like crazy (grey colored smoke). I've pulled valve covers off way more times than I'd like to count, and the UVC harnesses are fully clipped in (and have the updated clips to keep them from popping off).
So I'm seriously doubting it's a UVC harness issue (no P1316 that is typically associated with it). It does this with or without a chip. With very little to go on, I'm not sure what to start checking. I'm going to re-ohm the passenger's side valve cover one more time just to make sure, but after that I need some suggestions.
Anyone?
Curtis
2002 F-250 PSD
Gambling with 250/200's on PMR's.
478hp/851tq on Haller's dyno - 7/28/12
Your connection to the
Pocket is offline
post #2 of 15 (permalink) Old 05-04-2010, 07:17 PM Thread Starter
<-- it's like that
Re: Intermittent problem starting
Ohm'ed out the UVC harnesses. Glow plugs are 0.7, injectors at 3.5. So UVC is good.
Curtis
2002 F-250 PSD
Pocket is offline
post #3 of 15 (permalink) Old 05-04-2010, 08:51 PM Thread Starter
<-- it's like that
Wiring harnesses are good. No bare wire anywhere.
I'm stumped now. Today it's starting up just fine every time.
Curtis
2002 F-250 PSD
Pocket is offline
post #4 of 15 (permalink) Old 05-04-2010, 10:58 PM Thread Starter
<-- it's like that
Well I have an idea to try before swapping an IDM out. I think I'm going to pull the valve cover off on the passenger's side, then swap the connectors on #5 and #7 (don't worry, I won't start the truck like this). With them swapped, I'll do another buzz test and see if the problem moves to #5, or stays with #7.
Thoughts?
Curtis
2002 F-250 PSD
Pocket is offline
post #5 of 15 (permalink) Old 05-05-2010, 03:28 AM
OEM Moderator
Tom S's Avatar
I think that is a clever idea. I can also help if you cannot get with Sam on that part but I am gone this weekend and thurs/friday so tomorrow would be it.
Tom S is offline
post #6 of 15 (permalink) Old 05-05-2010, 02:09 PM Thread Starter
<-- it's like that
Thanks Tom! I'll let you know what I find out.
Curtis
2002 F-250 PSD
Pocket is offline
post #7 of 15 (permalink) Old 05-05-2010, 02:14 PM
All done now
Arisley's Avatar
Thoughts?
Sneaky. Easier than swapping injectors. I am thinking IDM though.
Arisley is offline
post #8 of 15 (permalink) Old 05-05-2010, 02:15 PM
All done now
Arisley's Avatar
BTW, when you come through DFW, give me a shout, I will buy you lunch.
Arisley is offline
post #9 of 15 (permalink) Old 05-05-2010, 03:58 PM Thread Starter
<-- it's like that
Thanks for the offer, but unfortunately I won't be going through DFW. I have a different route that I take when I'm coming from the panhandle down to Houston.
Curtis
2002 F-250 PSD
Pocket is offline
post #10 of 15 (permalink) Old 05-05-2010, 04:10 PM
All done now
Arisley's Avatar
I see. Hope you figure out your truck issue.
Arisley is offline
Human Verification
