Hard steering FIXED - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 04-10-2010, 02:14 AM Thread Starter
Canadian Stroker
doubledoor's Avatar
Talking Hard steering FIXED
Well after spending alot of time and money I finaly fixed my hard steering problem! With the help of a couple PSN members that convinced me to go to ford and buy one of their p/s pumps I did. Here is the quick version. After 8 years I got hard steering when not moving. Put a parts store pump on. No better. Put a ford one on. A little better. Took it back and put another ford one on. BAM problem solved.
2002 XLT CC LB 6speed SRW
4"mbrp turbo back
S&B Intake
autometer NV boost,pyro,water temp and oil pressure
WW2,BRV
DP tunes - QI,60E,80E,40T,60T,100,120.
EBPV delete sensor.
blank pedestal and EBPV housing
ATS turbo housing
DI up-pipes.
2007 headlights,2008 taillights,2010 tailgate
17"Atx ledge with Dick Cepek Extreme Country
doubledoor is offline
post #2 of 10 (permalink) Old 04-10-2010, 04:55 AM Thread Starter
Canadian Stroker
doubledoor's Avatar
Re: Hard steering FIXED
What nobody is going to say don't waste your time and money that is just the way they are?? It is normal to have hard steering.
4"mbrp turbo back
S&B Intake
WW2,BRV
EBPV delete sensor.
ATS turbo housing
DI up-pipes.
post #3 of 10 (permalink) Old 04-10-2010, 08:28 AM
Myles_S's Avatar
Not hard..but not as easy as hwy driving speeds.
PS pump in run of engine rpm so at a idle there's not as much fluid pumping through
99.5 F250, 4x4, Lariat, CC/SB, 4r100 Gauges, Intake, Exhaust, Lots of black/smoked parts
Originally Posted by Coltaine View Post
I ride solo, being able to converse with yourself is a skill that creeps up on you.
Black Ops 360
Gamertag; See Ya LATER 73
Myles_S is offline
post #4 of 10 (permalink) Old 04-10-2010, 11:03 AM
dinnerbooter treasurer
genuineford's Avatar
I got a NAPA pump and it steered like crap, I broke that one pulling my engine out and went and found the cheapest one I could get. It was from oreilys auto and the thing works better than it ever did.
93 F350 Gasser
03 F250 6.0
dinnerbooter #3
genuineford is offline
post #5 of 10 (permalink) Old 04-10-2010, 01:06 PM
Congrats man. I have heard horror stories about this. Mine has always steered fine, even when still. It gets a little more difficult when I am running my 33x12.5 tires, but with stock it is fine. Glad to hear you got it solved.
2002 f-350 PSD, 4x4, cc short bed, 6spd, ccv mod, airdog, AIS filter, isspro ev and scangauges, detroit TT, ITP boost annihalator, ITP RR, bellowed up-pipes, ats housing, turbomaster, 3.5 dp magnaflow, very happy with ultra smooth and linear PHP 50t, 80DD and "whisper" tunes.
clydesdale is offline
post #6 of 10 (permalink) Old 04-10-2010, 03:49 PM
OEM Moderator
Tom S's Avatar
Why is it so damn tough to get a good replacement Power Steering pump.
Tom S is offline
post #7 of 10 (permalink) Old 04-10-2010, 05:14 PM Thread Starter
Canadian Stroker
doubledoor's Avatar
There is no quailaty in rebuilds. Our trucks are so heavy that if the pump is not running at 100% pressure it wont turn. The first one I got from ford if you reved it just alittle it would turn easy. So the pressure was almost there. Such a fine line between working and hard steering.
4"mbrp turbo back
S&B Intake
WW2,BRV
EBPV delete sensor.
ATS turbo housing
DI up-pipes.
post #8 of 10 (permalink) Old 04-11-2010, 04:52 AM
Hydraulic ram and high output pump fixed my issues. Even with an 11' snowplow
'03 7.3 CC
boonman is offline
post #9 of 10 (permalink) Old 04-11-2010, 08:07 PM
Phiber Optik's Avatar
any more info on this high output pump you speak of?
2008 F-350 CC SB Lariat, 4wd, 20x12, 35x14.5, 4" lift w/ Bags, 4" Exhaust, IC Pipe, Elbow, S&B Intake, EGR Delete, Gearhead Tunes, Hellwig Sways, Recon Ltng
2000 Corvette - JT Trim Vortech
2007 HusaberG FS650
2008 RZR - Z1 Turbo
Phiber Optik is offline
post #10 of 10 (permalink) Old 04-12-2010, 03:28 PM
wampaku's Avatar
give agr a call. or go to agrperformace.com . they make an upgraded factory and a saginaw replacement. if you do the saginaw you need to get your hydroboost ported or you will shear the pump shaft.
1999.5 f350 xlt 4x4-afe stage ii intake, wicked wheel, 4" hog performance exhaust, dp tuner chip, 8" lift with 40's, arb's front and back, etc.
2002 excursion limited 4x4- afe stage ii intake, 4" hog performance exhaust, and dp tuner f5 chip
2005 vw jetta tdi- q loader chip for now
wampaku is offline
Human Verification
