Need help with 2002 f-250 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 05-19-2017, 02:15 AM Thread Starter
Blackhawk Mech
Blackhawkmech's Avatar
On my 2002 f-250 I have a bad humming noise at 65+. However when I hit a bump it give a quick and short buuuurrtt almost like an a-10 cannon. It's only about half a second long. I yanked as hard as I could on the rear driveshaft and no play at all. I played with the front drive and some play. I put it in 4 wheel drive and I have about a half inch of play by twisting the driveshaft. I don't think it's u joints cause the entire shaft is rotating that half inch all the way into the transfer case. Above 50 I do hear slap if I let off the gas really quick? Could I have a transfer case issue?
Blackhawkmech is offline
post #2 of 3 (permalink) Old 05-19-2017, 12:57 PM
410customs's Avatar
Re: Need help with 2002 f-250
how are your front wheel bearings?
1997 CCFB 7.3, ZF5, 4x4, 4.10, baby swamps, TS6, RSK
2001 Excursion 7.3, auto, 4x4, 3.73, freight train family hauler, collecting parts for suspension lift
2000 E350 7.3, auto 2wd, 3.73, toy hauler camper conversion...researching 4x conversion
21.9 liters there is no replacement for displacement!!
410customs is offline
post #3 of 3 (permalink) Old 05-19-2017, 03:06 PM Thread Starter
Blackhawk Mech
Best way to check those is jacking it up and checking for play in the wheel right? And the front wheel bearing are enclosed in the locking hubs correct?
Human Verification
