Flippy the Powerchoke! early 99 F350 7.3 truck flip project - PowerStrokeNation : Ford Powerstroke Diesel Forum
 14Likes
post #1 of 70 (permalink) Old 03-30-2017, 01:55 PM Thread Starter
410customs's Avatar
My stepsons and I found a smoking deal yesterday and drove it home to the shop!!!
Early 1999 F350 cab and chassis 7.3 auto extended cab, 221K miles, no bed, runs and drives but lacks power
We will fix this truck up nice and sell it, we split on her three ways, should be a fun project, using what we have learned on our own 7.3's to revive this old girl.
The family that plays together stays together!
Paid $1500, yes that's right $1500 and drove it home 30+ miles
Everyone I introduce to you the first family flip truck, Flippy the powerchoke!
First up, do all 99 trucks have a front/rear brake caliper setup on the rear axle or is this a cab and chassis thing?
Starts and runs okay just has no power, no input from the fuel feed pedal, no smoke, just a big time lack of power.
We started by cleaning the battery terminals so she would start on her own (corrosion) battery terminals still need a re visit but at least now shes getting power enough to run.
We then removed all the intercooler piping and boots, intake spider for cleaning, signs of leaks at every clamp. So we degreased all of this and had a good look at the 7.3.
ICP has oil in the harness, ordered a new one & pigtail.
Air filter was caked full of dirt, new one on its way.
Turbo has no play in it, but compressor wheel is a bit dusted.
Map sensor feed tube had a crack in it, cut off 1/2" of the tube and re connected.
Drivers up pipe large leak at turbo manifold, can hear the leak from inside the cab
Fuel bowl full and fuel is green, new filter on its way
Coolant at level, coolant nice and clear.
Has newer block heater (at least the cord) and oil cooler looks to have been replaced.
Has newer fuel pump
Has reman alternator (yuck) single alternator
Window sticker says oil changes done at Ford dealer, so I will run a carfax for some maint history
Transmission is not stock, looks very dry and shifts wonderfully, fluid is a little burned but still red in color.
No major leaks, valley has small puddle under turbo ped. otherwise very dry on sides and under block
"Chugs" a little at idle like it has a miss, never smooths out, always there
No grey or blue smoke from exhaust when warm, just small puffs of black, seems like a stock superduty.
Tires are near new, 3.73 limited slip rear, late 98 build date.
Plans so far:
Power wash!!! so we can work on it, this thing has never been washed under the hood.
Cylinder contribution and buzz test
Fuel PSI test
Boost test (maual gauge)
Rebuild turbo with garret kit and 360 degree thrust bearing
New glowplugs
Rosewood reman injectors
Clean fuel filter screens in tank and fuel bowl
compression test while VC are off
Clean EBPS and feed tube
re seal top of engine as needed (oil rails, fuel lines, etc)
deleted pedestal and EBPV
Flatbed (found a good deal on one)
front pushbar (already have)
Detail interior, fix whatever does not work
Steering is loose, likely needs front end work
R&R drivers mirror
Sell for profit! and then go buy another.........
Thatchevyguy and evans735 like this.
1997 CCFB 7.3, ZF5, 4x4, 4.10, baby swamps, TS6, RSK
2001 Excursion 7.3, auto, 4x4, 3.73, freight train family hauler, collecting parts for suspension lift
2000 E350 7.3, auto 2wd, 3.73, toy hauler camper conversion...researching 4x conversion
SEVEN POINT THREE LEAKER
410customs is offline
post #2 of 70 (permalink) Old 03-30-2017, 02:31 PM
Moderator
Sbluke55's Avatar
Re: Flippy the Powerchoke! early 99 F350 7.3 truck flip project
Looks like a good start BUT. If it's a true E99 I would look at parting it out. Then you can have an inter cooler. But then again with a little effort you could make some $$
01 f-250, Standard
Sbluke55 is offline
post #3 of 70 (permalink) Old 03-30-2017, 02:56 PM Thread Starter
410customs's Avatar
Don't worry there will be part outs, this one is a flip! Part of what we do here is save the clean ones, I take pride in that.
We are all drooling over the parts, I need intercooler bits and a builder engine, my stepson needs a cab for his rusty 01 and my other stepson is looking at the trans, frame and axles as $$$$ for parts... but we will save this one.
Its a true E99 as far as my limited knowledge goes, build date late 98, small turbo, AB injectors
I spent 45 minutes cleaning that intake spider yesterday, drooling. I spent $500 on the truck, the spider alone would cost me $350+ on Ebay!
V8 explorers have had their day... this lot will likely be filled with title-less, blown up superduties in no time. Especially if my now grown into men stepsons and I can work together (been working on relationships since they were teens now both married with kids), this is a great start! The wives are pushing us to do this together too, maybe we can even get the kids to hand us tools :) Hands on is how I learned RBV... time to do the same with powerstrokes
post #4 of 70 (permalink) Old 03-30-2017, 03:05 PM
Moderator
Sbluke55's Avatar
If it only has one relay where the gpr is its an e99. If there is two it's a L99 motor.
01 f-250, Standard
Sbluke55 is offline
post #5 of 70 (permalink) Old 03-30-2017, 05:55 PM Thread Starter
410customs's Avatar
flip flop brakes, is this to fight axle wrap up??
That one is a first for me
Should be easy to service the fuel pickup/sender
post #6 of 70 (permalink) Old 03-30-2017, 06:04 PM
Moderator
Sbluke55's Avatar
I think it was for just making one backing plate to use on both sides. Saves $$$ on tooling.
Definitely snag that rear sway bar for your ex. The new owners won't miss it.
01 f-250, Standard
Sbluke55 is offline
post #7 of 70 (permalink) Old 03-31-2017, 01:55 AM
Native Texan
masakimm's Avatar
Garage
Ok I'm going to have to hire you to find things for me you seem to find all the great deals.
95 F350 XLT SuperCab Dually
Engine Upgrades:
|Bellowed UpPipes|Stage 1 Injectors|Baby Badger Hpop|Rebuilt Turbo 360 Bearing|Custom E-Fuel|Manual to Auto Conversion
|Delete Pedestal|3" Down Pipe 4" Exhaust|Dual Tensioner and Belt|Stainless Steel HPX Crossover|Banks InterCooler
|42 Gal Rear Tank 38 Gal Front Tank
masakimm is offline
post #8 of 70 (permalink) Old 03-31-2017, 01:36 PM Thread Starter
410customs's Avatar
Okay cool $20 an hour Ill find it, if its on CL in North America I can find it, run to it, haggle, pay cash and haul it home!
<-----------------------------desk jockey
which is why as soon as I can, I leave this dang computer screen and go wrenching!
So we agree this is an E99? only one relay
I will try and get the sway bar, with those rear leafs I cannot imagine much body sway on this sucker
post #9 of 70 (permalink) Old 03-31-2017, 02:11 PM
Moderator
Sbluke55's Avatar
The motor is an E99 for sure. Front axle should be. You will have to check the u bolts. Are the round or square.
01 f-250, Standard
Sbluke55 is offline
post #10 of 70 (permalink) Old 04-01-2017, 02:40 AM
Where is the VIN plate? If on the front radiator support, just behind the passenger side headlight, it's an E99.
1996 F250 CCSB, 4x4, auto PSD, stainless window vents.
Signature file limitations keep me from sharing more information. Follow this link to find my threads: D60 RSK install, Air vent cleaning, etc.
leojr is offline
Human Verification
