7.3l brand new Alternator tests good but won't charge in truck. - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
post #1 of 23 (permalink) Old 03-29-2017, 04:31 PM Thread Starter
New guy here having an alternator issue. I purchased an OEM replacement alternator for my 03 7.3l 250.
Alternator doesn't work, I took it to an alternator shop and the guy tested and it ran fine.
He told me that I could have an issue with the fusible link in my battery wire or in the regulator wires.
He also said one wire goes from the ignition switch to the regulator and the other side goes to one side of the battery light indicator.
He also explained that the wires tend to rub threw at the valve cover wire harness connector.
I believe all this to be true hopefully you all can shed some light for me.
I really need a wire schematic that shows where the wires are goin because it sounds like I will need to do some rewiring. I am capable of doing this. This is just my first 250 just need to be pointed in the right direction.
Any guidance out there?
Joseph Jozwiak is offline
post #2 of 23 (permalink) Old 03-29-2017, 06:27 PM
410customs's Avatar
Re: 7.3l brand new Alternator tests good but won't charge in truck.
check your fuses, there will be one that says alternator or generator
Is the battery light on in the dash?
The ford alternator has a built in voltage regulator that must get power from the dash or your good alternator will not charge
The fuse is on the power side of the voltage regulator
1997 CCFB 7.3, ZF5, 4x4, 4.10, baby swamps, TS6, RSK
2001 Excursion 7.3, auto, 4x4, 3.73, freight train family hauler, collecting parts for suspension lift
2000 E350 7.3, auto 2wd, 3.73, toy hauler camper conversion...researching 4x conversion
SEVEN POINT THREE LEAKER
410customs is offline
post #3 of 23 (permalink) Old 03-29-2017, 06:30 PM
79jasper's Avatar
There's also fusible links on the charge wire.
Sent from my SAMSUNG-SM-G935A using Tapatalk
79jasper is offline
post #4 of 23 (permalink) Old 03-29-2017, 07:43 PM Thread Starter
Yes the battery light is on and I will check fuses when I get home.
post #5 of 23 (permalink) Old 03-29-2017, 07:44 PM Thread Starter
I know about the fusible link it is good.
post #6 of 23 (permalink) Old 03-29-2017, 07:50 PM
Moderator
Sbluke55's Avatar
You should have power to one of the small wires on the alt. Without power there. It won't charge. Can't remember the color.
I actually run an alt from a ford ranger. It's a 160a vs the stock 120a. It's also a single wire alt. One wire runs to the light on the dash.
01 f-250, Standard
Sbluke55 is offline
post #7 of 23 (permalink) Old 03-29-2017, 08:22 PM Thread Starter
What year ranger alternator?
post #8 of 23 (permalink) Old 03-29-2017, 08:32 PM
Moderator
Sbluke55's Avatar
94 and up I believe. They come on many different engines. I grabbed one from a van. I believe the ones from an obs are the same. What your looking for is a large case 3G alt. You will have to change your pigtail. I got my alt from a junk yard along with the pigtail.
01 f-250, Standard
Sbluke55 is offline
post #9 of 23 (permalink) Old 03-29-2017, 08:35 PM
Moderator
Sbluke55's Avatar
Just an FYI. You will need to grind some material off of the accessory bracket under the alt to make them fit.
01 f-250, Standard
Sbluke55 is offline
post #10 of 23 (permalink) Old 03-29-2017, 09:55 PM
alleged moderator
tjctransport's Avatar
closely inspect the plug that goes into the alternator. they tend to burn contacts, or the contacts disfigure and loose contact when they get hot.
tom
tjctransport is offline
Human Verification
