Do I even need a EGT gauge? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 02-17-2017, 03:53 PM Thread Starter
ocracokeisland's Avatar
Garage
I am fixing up my truck on a budget and adding a A-pillar gauge is expensive. I monitor everything else via Torque that works well but I can not see exhaust gas temps. My truck is stock except for a "wicked wheel". I daily drive the truck and tow a 4,100 to 4,500lb boat 50 miles a few times a month and maybe once a year I will tow it 1,000 miles.
I let the truck cool down when towing and never go over 65mph and even with 3:73 gears it does not seem to mind the boat too much. Thanks for the advice.
2000 Ford F250 Reg Cab, 4R100, 3.73 gears build date 10/1999
7.3 Power Stroke #1179548 built Oct 27 1999
Bone stock for now
ocracokeisland is offline
post #2 of 2 (permalink) Old 02-17-2017, 04:08 PM
Moderator
Sbluke55's Avatar
Re: Do I even need a EGT gauge?
If you dont tune it. No need to watch egts.
01 f-250, Standard
Sbluke55 is offline
Human Verification
