UVCH - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 02-16-2017, 03:20 AM Thread Starter
UVCH
I'm getting ready to tear the turbo of my truck to change the O-rings on the pedestal (praying to God thats my oil leak problem) changing glow plugs as well and glow,plug relay. I'm going to change the uvch as well since I'll everything torn apart (more of a preventive maintenance thing) my question is should I just do the harness or do the valve cover gaskets as well that the harness plugs into. I can get the whole kit from Napa for a pretty good price or if I don't need the gaskets then I can afford the Ford harnesses. Just can't afford $200+ on all ford stuff. 01 CCLB 4x4 147,000mi
Thanks guys for any advice I am using ford glow plugs btw
G.B.O.C.7.3 is offline
post #2 of 13 (permalink) Old 02-16-2017, 05:14 AM
Trust me, I got this...
Cummins Junkie's Avatar
Garage
Re: UVCH
The Harness and Gasket is one unit. I, personally, would go with the Ford ones.
Shoulda bought a Cummins.
1997 7.3L, 4x4, ZF-5, 305k, TS chip, 6637 filter, 4" straight piped duals...
Currently on lookout for axles for 05 swap and superduty seats
Cummins Junkie is offline
post #3 of 13 (permalink) Old 02-16-2017, 01:38 PM
410customs's Avatar
Re: UVCH
Alliant makes good parts, appear to be same as OEM if you ask me
I just installed new under cover wiring harness, valve cover gaskets and alliant pigtails = very happy with the quality and results
I got mine from Riffraff diesel that had great prices, it was around $275 for everything
Do NOT buy dorman or the cheap knock offs you will pay for it later, my $75 dorman gaskets did not make it 8 months
1997 CCLB 7.3, ZF5, 4x4, 4.10, brought back from the dead
2001 Excursion 7.3, auto, 4x4, 3.73, new to us freight train family hauler
I build custom trucks and off road toys in my private shop located in Crawlorado
410customs is offline
post #4 of 13 (permalink) Old 02-16-2017, 02:38 PM Thread Starter
Re: UVCH
OK I looked on Riffraff site and it shows just the harness for $59 then it shows the valve cover gasket for another $60, I'm trying to figure out if I can reuse my valve cover gaskets or if they should be replaced also. Everything I'm looking up online looks like the harness and the gaskets to which the the harness plugs into are two separate things. I'm new to these motors so I'm going off pictures I've seen online
post #5 of 13 (permalink) Old 02-16-2017, 02:46 PM
410customs's Avatar
Re: UVCH
The only way to know if you can re use your valve cover is to inspect it and see if the plastic is melted/cracked if the rubber seal is soft or hard, and if the wiring pins are good or not.
Chances are they are still good unless you have had glow plug issues
The wiring Riffraff sells will plug into OEM gaskets on both sides
The gaskets Riffraff sent me were listed as "navistar" on the ticket leading me to believe they were OEM / International pieces. The wiring pigtails are Alliant part numbers and work with OEM gaskets.
post #6 of 13 (permalink) Old 02-16-2017, 03:20 PM
Moderator
Sbluke55's Avatar
Re: UVCH
Just inspect them for burnt pins and melted plastic. If all is good just run them. Im at 220k on stock uvch's.
01 f-250, Standard
Sbluke55 is offline
post #7 of 13 (permalink) Old 02-16-2017, 04:42 PM
Luddite in Charge
Mr_Andy's Avatar
Re: UVCH
Weather strip works great for valve cover gaskets
Whatever you do, do not go aftermarket. ESPECIALLY Dorman brand. Complete garbage.
Ford will bend you over and hammer you without lube, go to International.
1830844C93 Harness $16 each side
1826703C1 Gasket $36 each side.
If you're stuck on Ford it's Ford F81Z-9D930-AB for the $70 harnesses and about the same for F81Z-6584-AA valve cover gaskets.
And if and when you call your local International dealer juyst tell them "it's a 444" and not in a Ford truck. Sometimes they feel a certain way when you mention their engines in Ford trucks.
As for your oil leak, have you ruled out the EBPV solenoid?
And only use the yellow Viton o-rings when you pull that turbo.
Ford Part number reference: F4TZ -6N653-A and F4TZ-6N653-B.
Mr_Andy is offline
post #8 of 13 (permalink) Old 02-16-2017, 08:24 PM Thread Starter
Re: UVCH
Hahaha I know they will already did for a new throttle pedal and of course a adapter bracket to make it fit, I'll definitely go the international route that's a lot easier on the pocket book. I did get the yellow O-rings and I have no idea if it's the EBPV I know hpop lines aren't leaking or the hpop, figured if it's not the O-rings I'll do them anyways cause I'm sure they will go out eventually
post #9 of 13 (permalink) Old 02-17-2017, 03:26 AM Thread Starter
Re: UVCH
Well called International and about choked on the price they gave me so I just ordered the harness and valve cover gaskets from Riffraff. Thanks everyone for all the advice and information very much appreciated
post #10 of 13 (permalink) Old 02-17-2017, 02:14 PM
410customs's Avatar
Re: UVCH
I did the same thing
Shopped local Ford, shopped local international, shopped all over online and ended up with Riffraff.... they ship fast and have excellent prices and products = for the win!
Human Verification
