significant oil leak - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 01-09-2017, 10:04 PM Thread Starter
My 2001 F350 4x4 is leaking oil, and I don't mean a "drip". I'll preface my post by saying this is my 1st 4x4, and 2nd diesel (though I've only had a diesel since April). Truck is parked facing slightly downhill. There is a stream of oil a couple of feet long. It appears to be originating on the driver's side of the engine somewhere behind the front diff. It's not from the valve cover or intercooler tube, but is running down the crossmember and seems to be coming through around the slotted hole (that appears to be) for the engine mount. Does engine oil drive the 4x4 switching? There are a couple of hydraulic lines between transfer case and front diff that look pretty wet. Any direction is appreciated.
Thanks!
tmsbandman is offline
post #2 of 13 (permalink) Old 01-10-2017, 02:30 AM
Moderator
Sbluke55's Avatar
Re: significant oil leak
Most likely leaking oil cooler. There is a rebuild kit for it. Dont used dorman. Ford or international only
01 f-250, Standard
Sbluke55 is online now
post #3 of 13 (permalink) Old 01-10-2017, 02:34 AM Thread Starter
Wouldn't the oil cooler be with the radiator/trans cooler/intercooler? This is definitely farther back. Where does the oil leave the block to be cooled?
post #4 of 13 (permalink) Old 01-10-2017, 02:38 AM
Moderator
Sbluke55's Avatar
Oil cooler is on the driver's side of the block. Its the piece the oil filter screws onto.
01 f-250, Standard
post #5 of 13 (permalink) Old 01-10-2017, 02:53 AM Thread Starter
Yep. Thanks a lot. Just watched a great video on rebuilding it. Doesn't look bad. I'll get under there in the next day or two to confirm the leak location. May just be adding oil until I can get to the rebuild. It's not my daily driver. Other than the nuisance, is it urgent? It's not something that's gonna blow out and dump oil everywhere, is it?
post #6 of 13 (permalink) Old 01-10-2017, 11:34 AM
s10mike's Avatar
You better pick up like 8 gallons(i think) of antifreeze too. Oil cooler is fairly easy to rebuild.
2003 f250 lariat ccsb, 4x4. 7.3, bullydog 6 pos. chip, 6637, 315 tires, HD 4r100, badass stereo. 127,000 going strong
s10mike is offline
post #7 of 13 (permalink) Old 01-10-2017, 12:09 PM
Moderator
Sbluke55's Avatar
8 gallons of 50/50 mix or 4 gal of full strength.
I personally wouldn't drive it.
01 f-250, Standard
post #8 of 13 (permalink) Old 01-10-2017, 12:57 PM
410customs's Avatar
Don't drive it it until its fixed, can mix water with oil
1997 CCFB 7.3, ZF5, 4x4, 4.10, baby swamps, TS6, RSK
2001 Excursion 7.3, auto, 4x4, 3.73, freight train family hauler, collecting parts for suspension lift
2000 E350 7.3, auto 2wd, 3.73, toy hauler camper conversion...researching 4x conversion
21.9 liters there is no replacement for displacement!!
410customs is online now
post #9 of 13 (permalink) Old 01-10-2017, 02:39 PM Thread Starter
Ugh! Makes sense. I may have to do it one time. I need the truck Thursday, but the entire drive will be less than 10 miles, and nothing heavy.
post #10 of 13 (permalink) Old 01-10-2017, 02:45 PM
Moderator
Sbluke55's Avatar
Just keep checking it. The coolant and the oil levels.
01 f-250, Standard
Human Verification
