Did The Unthinkable, Put Gas in my 7.3!! Help! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 23 (permalink) Old 09-17-2009, 05:07 PM Thread Starter
HoosierRacer's Avatar
So last night I got in a hurry, wasn't paying attention, and accidentally pumped gas into my 02 F250 7.3's tank. I'll blame it on the 14 hr. work days the past two weeks, so i've been in a bit of a haze. Totally my fault, none the less.
I didn't start the truck, pushed it away from the pump and had it towed home. I was on empty and put about 17 gallons in before I smelled the gas and realized what I was doing. I need suggestions on the best way to get everything drained out and running with doing minimal damage to the fuel system. Thanks in advance!!
HoosierRacer is offline
post #2 of 23 (permalink) Old 09-17-2009, 05:09 PM
Young'n
powerstrokeracing's Avatar
Re: Did The Unthinkable, Put Gas in my 7.3!! Help!
ive never done that, but i would say drop the tank completley drain it, and maybe wash it out. but since u didnt start i wouldnt imagine it went far in the fuel system
powerstrokeracing is offline
post #3 of 23 (permalink) Old 09-17-2009, 05:19 PM
<--Spy Vs. Spy
theSLEEPER's Avatar
You could probably siphon as much as you could out and fill it up and be OK....
228-365-0698
Sheep only have two speeds, 'grazing' and 'stampede'.
Regulated Returns are on SALE!!
theSLEEPER is offline
post #4 of 23 (permalink) Old 09-17-2009, 05:42 PM
ADubDiesel's Avatar
As long as you didn't start it, you're fine. Either siphon it or drop the tank. Refill with diesel and be good to go.
1995 Ford F-250 7.3 (Sold)
1998 Nissan Maxima 3.0
ADubDiesel is offline
post #5 of 23 (permalink) Old 09-17-2009, 05:57 PM
Addicted to Boost
JToy's Avatar
It could be worse, you could've started it
Nebraska
JToy is offline
post #6 of 23 (permalink) Old 09-17-2009, 06:38 PM
All done now
Arisley's Avatar
Just go down and buy one of those cheap 12V fuel pumps. Looks like a block. Unhook your fuel line where it attaches to your fuel pump, hook it to the new fuel pump. Run a line from there and fill up all of yours, and all your neighbors gas cans. When it is empty, dump about ten gallons of diesel in and go on your happy way.
And like every body else said, glad you didn't start it.
Arisley is offline
post #7 of 23 (permalink) Old 09-18-2009, 12:08 AM
Layson's Avatar
Couldn't you just unhook your fuel pump.. and use it to empty out your tank.
Layson is offline
post #8 of 23 (permalink) Old 09-18-2009, 12:57 AM
17 gallons is a lot if it was only 3 or 4 you could just have filled up the rest of the way with diesel and been okay. I don't see why you couldn't undo the pump and get it to pump it out but you'd need to be careful not to run the pump dry for very long.
Pat
2003 2500hd ccsb, intake 5" straight pipe, ad2 165, Bosch remans, ride right bags, tinted windows, ppe boost valve, on the way leveling kit 285's, efi live, built trans and batmo wheel
1996 E350 4x4 sled puller Draggin Wagon
Carpenter's local 2214 St. Louis, MO
silverf250 is offline
post #9 of 23 (permalink) Old 09-18-2009, 01:12 AM
PSDfan99's Avatar
If it was determined to be ok to pump gasoline through the diesel fuel pump, then I'd just disconnect the output line on the fuel pump and put a rubber hose on it so you can direct the fuel to some gas cans or buckets and then just turn the key on and let the fuel pump pump it out. Granted the fuel pump will shut off after a few seconds, its still easier than dropping the tank.
Early 99 F-350
4" lift on 33's. Daily Driver/ Plow truck.
Swamp's Gen3, 300/200's, Tuning, 76mm Sledgehammer. BTS. Fuel system, ARP's, P-Rods, 910's, and a few other things. Stock Block.
SOLD
New truck:
2009 F-350, 5.4L, 4" lift on 35's
PSDfan99 is offline
post #10 of 23 (permalink) Old 09-18-2009, 04:11 AM
I accidently put 2 gallons of gas with 30 gallons of diesel. Sure did run good....
09 F450 6.4 PSD 5r110 4x4, H&S XRT Pro, Edge CTS Insight
schmity is offline
Human Verification
