gtp38 turbo specs? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 08-28-2009, 05:43 PM Thread Starter
Lovin the Tuna
RedSmokey's Avatar
gtp38 turbo specs?
What size are the wheels on a stock 7.3 gtp38? is a WW a different size, or just different pitch on the blades.
And to add, pardon my lack of knowledge, but how do you actually measure the size? I know its mm but where are you measuring?
2001 F250
2000 F250
RedSmokey is offline
post #2 of 5 (permalink) Old 08-28-2009, 09:32 PM
Layson's Avatar
Re: gtp38 turbo specs?
They are the same size, just different amount of blades and probably different pitch.
Layson is offline
post #3 of 5 (permalink) Old 08-28-2009, 09:35 PM
<--Spy Vs. Spy
theSLEEPER's Avatar
Why was I thinking a 38R had a 66mm wheel? Or was it an 88mm?
228-365-0698
Sheep only have two speeds, 'grazing' and 'stampede'.
Regulated Returns are on SALE!!
theSLEEPER is offline
post #4 of 5 (permalink) Old 08-28-2009, 09:42 PM Thread Starter
Lovin the Tuna
RedSmokey's Avatar
Thanks Steven! And Jap, i dunno, im trying to figure out what our stock ones are... I have an idea, but i need to figure this stuff out.
Also if anyone knows what the stock wheel is on a 6.0? The A/R on the exhaust and the compressor housings?
2001 F250
2000 F250
post #5 of 5 (permalink) Old 08-29-2009, 03:12 AM
krankin's Avatar
Stock is 60mm inducer, 80mm exducer. 38r is 66 inducer and 88 exducer.
If I was close to a 6.0 right now, I'd go look at the A/R specs for you but i'm not, sorry
Kevin
00 F250 7.3 Ex Cab LB, 6-spd, South Bend Con-O, DP Tuning, Casserly 230/80% Hybrids, GTP38R, Reg. Return, AutoMeter Boost/Pyro/Fuel Press, MBRP 4", Napa 6637, ITP OBA, 04 Headlights, Ranch Hand Rear
04 F250 6.0 CC SB, SCT with tunes by Elite, MBRP 4", Isspro Boost/Pyro, Warn manual hubs
92 Bronco
75 Jeep CJ-5
krankin is offline
Human Verification
