Compression Test 7.3 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 07-07-2009, 01:30 AM Thread Starter
PSD
CNDiesel's Avatar
How would I go about to do one??
-Disconnect valve cover gaskets
-pull glow plugs
thread in compression tester
crank engine by starter???
Record # (what numbers should I be looking for)
orrr??....
1996 crew cab long box. 3.73s, auto 493/1135 stockish auto trans.
CNDiesel is offline
post #2 of 6 (permalink) Old 07-07-2009, 01:33 AM
matthewd11's Avatar
Re: Compression Test 7.3
Pull ALL the glow plugs and the PCM fuse.
Thread in the tester, crank the engine with the starter, count 4-5 puffs. The first puff and the last puff are most important.
matthewd11 is offline
post #3 of 6 (permalink) Old 07-07-2009, 02:24 AM
Member
vapstroke's Avatar
throw a batt charger on while your doing it.
Swamps, ITP diesel, DP tuner, BTS, Stecher Performance Diesel, DieselSite
vapstroke is offline
post #4 of 6 (permalink) Old 07-07-2009, 02:54 AM
matthewd11's Avatar
It is a good idea, but with the glow plugs removed they wont be fighting compression.
post #5 of 6 (permalink) Old 07-07-2009, 03:19 AM
lets roll
thunderstroke's Avatar
you can also just pull the idm relay so it wont fire as well. Thats the "by the book" method
2000 f-250, dp f-5, ddp 120hp single shots, mbrp turbo back, itp boost fooler, itp pre-pump kit, banks billet torque converter, coolingmist cmgs
thunderstroke is offline
post #6 of 6 (permalink) Old 07-07-2009, 07:11 AM Thread Starter
PSD
CNDiesel's Avatar
Ill do that, I dont know where the PCM fuse is anyway.
CNDiesel is offline
Human Verification
