7.3 white smoke rough idle Help please - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 06-17-2009, 07:03 AM Thread Starter
F350red
Send a message via Yahoo to f350red
Hello all
I just bought a 2001 f250 7.3 234.000 miles
The guy I got it from put Engine Restore in it and it stopped running. I put in 2 new Batteries and used WD-40 and starting fluid and got it running. Rough idle, lots of white smoke. It has good strong power with no miss above 30 miles an hour. I drove it home 250 miles and used 2 quarts of oil. I not thinking put a can of Engine Restore in it and the motor stopped running. I had to use WD-40 and starting fluid to get it going again.
My thinking is that if the Engine Restore made the motor stop the way it did is that I have a cracked injector and or bad O-rings with warn sleeveís.
I donít have the $$$ at this time to put in all new injectors. I am going to install all new O-rings and any bad injectors with new sleeves at this time. What tool do I need or make to remove the sleeveís?
Any and all in-put is welcomed
Thank you for any help
F350red
Mitch--f350red
f350red is offline
post #2 of 6 (permalink) Old 06-17-2009, 11:42 AM
The Fireman
big_stroker's Avatar
Re: 7.3 white smoke rough idle Help please
Why don't you do some testing on it 1st b4 you start taring into it.
big_stroker is offline
post #3 of 6 (permalink) Old 06-17-2009, 04:35 PM
Genius, when I drink
ditch_dawg's Avatar
Does the smoke smell like diesel fuel? If it clears up above 30mph you may just have a sticking injector, which will give a rough idle. Does it always run bad below 30mph? Or is it just the first start of they day?
Using 2 quarts of oil (assuming none of this made it to the ground or out the tail pipe....ie bad seal on the turbo) may indicate bad o-rings on the injectors. Check your fuel filter and see how oily it looks. If it's pretty nasty then yes you have leaky o-rings.
'03 F250 CC
"Beer is proof God loves us and wants us to be happy" Benjamin Franklin
Originally Posted by golfer View Post
blip the throttle, and you just changed your "HPOP" oil
put that on youtube
ditch_dawg is offline
post #4 of 6 (permalink) Old 06-18-2009, 12:12 AM Thread Starter
F350red
Thank you all found a place $65.00 to do the testing. He only sells new fuel injectors, $265.00 each
Mitch--f350red
f350red is offline
post #5 of 6 (permalink) Old 06-18-2009, 01:16 AM
suprdzlduty's Avatar
do some searching on injectors you can find them cheaper than that. check out site sponsors for starters. if your tight on money consider a rebuilt injector if you just need something to get you by for a while.
04 CCSB Lariat, 4x4, studded & deleted(Elite), Garrett stage 1(DI), Innovative tunes, DS coolant filter, FS2500, Banks intercooled, 17x9 MT classicII's, Nittos, trans rebuilt by me, B&M shift kit, billet converter...sold
04 F450 RC studded & deleted(FCDP), alum. wheels, pulls the gn.
05 build in progress...
suprdzlduty is offline
post #6 of 6 (permalink) Old 06-18-2009, 02:56 AM
fueled by Colecovision
golfer's Avatar
Garage
I would run a compression test on the engine before I spent a dollar on it.
golfer is offline
Human Verification
