What are normal MAP datastream values? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 05-30-2009, 10:21 PM Thread Starter
Boost Addict!
I have a 99.5 F250 7.3 with 174K on the clock. Was recently looking around at the datastream on a SnapOn Solus Pro. I noticed the MAP readings seem a bit funny. BARO = 100, normal. At idle, MAP kPA is 83. which may be about normal.. but, the MAP Hz PID always reads 0.. at idle, while driving, etc. What is a normal Hz value for the MAP sensor?
99.5 F250 PSD - 2" lift, 35s, Detroit Locker, TS Performance 6-position flip chip, 4" straight-piped exhaust, TS Intake
2003 VW Jetta 1.9 TDI - 50 mpg :)
ASE Certified
srvblues00 is offline
post #2 of 3 (permalink) Old 05-30-2009, 11:19 PM
<-Tis the YZ SeasonWOOHOO
Calico5's Avatar
Re: What are normal MAP datastream values?
The MAP sensor output is an analog voltage, not a proportional/frequency-based (modulated) output.
You won't see any "Hz" reading, because it's a straight DC output.
The scan below shows the output voltage relative to input absolute pressure (psia) (scroll down to the bottom of the pic):
Al in SoCal
2000 F350 C-C SRW 4x4 6-Spd
The Usual Stuff: AFE Intake, 38R Turbo, Big IC, Stealth Big oil, Stock AD Smokesticks, DP F5 Chip & PCM: "Live Tuned", Custom Fuel System, Non-EBPV Pedistal , 'T444' CCV, 4" S/S exhaust, Dual "Aussie" Stacks, SB Double-disc clutch
Calico5 is offline
post #3 of 3 (permalink) Old 06-03-2009, 01:49 AM Thread Starter
Boost Addict!
Thanks for the info, that's what I was wondering!
ASE Certified
Human Verification
