Stock Boost Pressure - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 31 (permalink) Old 04-09-2009, 03:09 AM Thread Starter
Just hooked up my boost guage tonight and it peeks at 15#. From what I've read that is right on for a bone stock 99 7.3. Can anyone confirm this to be true?
Adam
Morningstar908 is offline
post #2 of 31 (permalink) Old 04-09-2009, 03:11 AM
Super Hauler!
Super_Hauler's Avatar
Re: Stock Boost Pressure
early 99 or late 99? I can hit 23 pretty easy with my stock early 99 and used to hit 24 with my late 99.
Super_Hauler is offline
post #3 of 31 (permalink) Old 04-09-2009, 03:23 AM
owner/president
dixieland-diesels's Avatar
Send a message via MSN to dixieland-diesels
Check your intercooler boots for leaks.
03 lariat cc,4x4 7.3,DP-F5,36''MT,8"lift w/trac.bars,4"Silverline ss.exh,AFE II,Optimas,ATS housing,WW,Turbomaster,6.0 IC & tranny cooler,BTS,ISSPRO gauges,HPX,ITP RR,BRV+,Powerslots,WARN prem-hubs,coolant filter,ccv mod,08 mirrors,ARP's,mod.fuel & inj's.,Crower rods,AIH delete,AMSOIL fluids. ~waitn on the 38R~
dixieland-diesels is offline
post #4 of 31 (permalink) Old 04-09-2009, 03:28 AM
JHill's Avatar
15 sounds a bit low, upipes? any soot on the firewall?
E '99 F-350 CC LB, ZF6, IDP -T4i Mount, Comp. Fuel System, , Reg. Return, Comp Valve springs, ARP's, DI P- Rods, Adrenaline HPOP, Isspro's, Detroit Tru Trac
238/200
ISM HX50
Tyrant Tunes
South Bend DD
JHill is offline
post #5 of 31 (permalink) Old 04-09-2009, 05:10 AM
Canadian Stroker
doubledoor's Avatar
I had leaking up pipes (not to bad.only one) The best I could hit when I was stock was 17psi. No boost leaks.
2002 XLT CC LB 6speed SRW
4"mbrp turbo back
S&B Intake
autometer NV boost,pyro,water temp and oil pressure
WW2,BRV
DP tunes - QI,60E,80E,40T,60T,100,120.
EBPV delete sensor.
blank pedestal and EBPV housing
ATS turbo housing
DI up-pipes.
2007 headlights,2008 taillights,2010 tailgate
17"Atx ledge with Dick Cepek Extreme Country
doubledoor is offline
post #6 of 31 (permalink) Old 04-09-2009, 05:35 AM
Cute and cuddly boys!
mazdaparts's Avatar
Send a message via Yahoo to mazdaparts
I'm pretty much stock for now (chip coming soon) and I can hit around 15psi easily and will get to 17-18 in 3rd gear if I have enough road. It seems to be climbing but I usually run out of road and 70+mph on county roads isn't the best idea.
2002 F250 Crewcab Shortbed 4X4 Totaled 6/16/12
2000 Expedition Eddie Bauer 4x4
There are 2 rules to getting ahead.
Rule #1. Don't tell anyone everything you know.
mazdaparts is offline
post #7 of 31 (permalink) Old 04-09-2009, 06:19 AM
hyrk's Avatar
Dont mean to steel your forum.just have a similar question.
just got a garrett 38r with 1.0 housing. getting 26 psi max...I was getting the same with the stock turbo. Have a spearco i/c, 4'' exhaust, intake, aswell. i was expecting more from the 38r. Could it be the edge attitude monitor is inaccurate?? Dont have a manual boost guage but its coming.
Reading your posts and seems as if there should be no way i could reach 26 with a stocker. 2002 7.3
hyrk is offline
post #8 of 31 (permalink) Old 04-09-2009, 11:26 PM
dmd
Member
dmd's Avatar
Stock max should be around 17lbs. 15lbs is about right if you dont have some
weight to really build the boost up.
dmd is offline
post #9 of 31 (permalink) Old 04-09-2009, 11:30 PM
NYFB. Thats what.
jontheturboguy's Avatar
Apple to oranges my friend.
Your 38R has a larger wheel in it. Although you are seeing the same boost #, you're actually flowing more volume.
jontheturboguy is offline
post #10 of 31 (permalink) Old 04-10-2009, 12:56 AM
I guess I will put in my .02 on both Q's. I have a 2000 with an auto and rock stock it would put out no more than about 15psi. Chip would get it to 21ish. I then disconnected my wastegate acuator line and with the chip could get to 28+. I ran it that way for almost 2 years. A week ago I installed a GT38R, I went with a 1.15 A/R housing and my boost numbers actually went down. (As I expected they would.) The truck seems to have more power throughout the RPM range though and I am happy with it. The GT38R actually maxes out at 28 right now with stock injectors and chip. Didn't want to take the factory turbo over 30, so it never got floored in 3rd or 4th gear with a load on it. (It surged too bad anyway)
To the OP, you can try to adjust the wastegate or even just pull the red line off the actuator and put it on one of the nearby hose clamps. I haven't heard of this causing any problems....and my experience with it says the same. I doubt it would give you much without a chip/tuner though.
-Aaron
GreenF350 is offline
Human Verification
