Clogged A/C Evaporator - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 04-03-2009, 01:13 AM Thread Starter
Nothing cool to say.....
vepr308's Avatar
My Evap is all clogged up with 'gunk'!
How do I clean it out without removing it?
I don't think compressed air will do it.
99 {late} F-250 SuperDuty PowerStroke 7.3L 230k [All stock as far as I know]
98 Ranger 4-Banger (A to B truck) [All Stock]
05 Hyundai Accent (Wifes Car)
07 BMS Power Buggy 800cc 2 Seater (kinda like a sandrail)
vepr308 is offline
post #2 of 9 (permalink) Old 04-03-2009, 02:38 AM
casper7.3's Avatar
Re: Clogged A/C Evaporator
i would think compressed air or replace it...but first, what is causing that? i've seen several construction trucks that i've replaced the heater cores in, but the evaporator's never looked that bad...even with all that dust in cab being recirculated on max a/c...got me?...is the evaporator leaking refridgerant causing it to collect dust?
LUKE
2002 CCLB AUT0 4X4
S&B, DI/PRICOL GAUGES, CCV, ZOODAD, TS CHIP-MATT AT GEARHEAD,
38R, ADRENALINE, SWAMP'S IDM, 4" T/B MBRP
05 CONVERSION, 4 INCH LIFT, 325/65-18 FIERCE ATTITUDE M/T
WILSON 5000 GALAXY DX66
casper7.3 is offline
post #3 of 9 (permalink) Old 04-03-2009, 03:17 AM
Genius, when I drink
ditch_dawg's Avatar
First off what caused you to check the evap? Was it not flowing any air out the vents? Or was it not putting any cold air out? If it's the later you may be low on charge and like Casper said if it's leaking at the evap it will collect debris there. There is a small amount of oil that circulates with the refrigerant to lubricate the compressor.....dust sticks to it a makes mud.
You can clean the coil. However, I have never done one while in a vehicle. It doesn't look like using compressed air would really do the trick. I'm sure you could use something like simple green to clean the coil.....I use a product call coil bright. Make sure the condensate drain is not plugged up, apply the cleaner, let it soak in, rinse with a small amount of water and repeat as necessary.
Hope this helps
'03 F250 CC
"Beer is proof God loves us and wants us to be happy" Benjamin Franklin
Originally Posted by golfer View Post
blip the throttle, and you just changed your "HPOP" oil
put that on youtube
ditch_dawg is offline
post #4 of 9 (permalink) Old 04-03-2009, 03:51 AM Thread Starter
vepr308's Avatar
I was having issues with air flow through the vents. It did blow cold.
I pulled the blower motor as my first suspect, that's when I seen the evporator.
Not sure what caused it to get so bad. Has 230K miles on it, and it used to be a fertalizer delivery truck. The whole truck was filthy when I got it...
Thanks for the ideas. I think I might try the Coil Brite bath.
vepr308 is offline
post #5 of 9 (permalink) Old 04-03-2009, 03:53 AM Thread Starter
vepr308's Avatar
How hard would it be to change the part at home? Evacuating and charging the system aside...
vepr308 is offline
post #6 of 9 (permalink) Old 04-03-2009, 04:03 AM
ford2go's Avatar
I have uesd this stuff works good may be something to try
http://www.lubegard.com/automotive/radiator_foam.html
Evaporator & Heater Core Foam Cleaner
ford2go is offline
post #7 of 9 (permalink) Old 04-03-2009, 04:07 AM
Caption This
444-4D's Avatar
How you clean it will depend on how that stuff that's on it responds to cleaning. If it is easily dissolved with some kind soap you can rinse it like ditch dawg said. If not you may have to remove it. If I removed it I would probably install a new one.
If only those who knew what they were talking about replied, this thread would still be on page one.
2000 F-250 CC 4x4 PSD Auto
444-4D is offline
post #8 of 9 (permalink) Old 04-03-2009, 04:08 AM Thread Starter
vepr308's Avatar
That looks pretty good too... hmmm Options...
vepr308 is offline
post #9 of 9 (permalink) Old 04-03-2009, 04:22 AM
ford2go's Avatar
I ues this stuff a lot on the simi trucks I work on and did ues it on my 95 f250 .I had the heater box apart to get the right head off and cleand the evaporator and heater core.
ford2go is offline
Human Verification
