Replacing turbo pedestal o rings - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 03-02-2009, 04:32 PM Thread Starter
<----My last CT scan
Motownfire's Avatar
I have to pull my turbo and replace the o rings cause mine are leaking. Anyone have any tips, tricks, hints or general know how to make this go easier for me. I have done just about everything else my self (install my injectors/convert to run WVO) so I am not too worried, I just haven't pulled a turbo on one of these. Thanks for any help.
Motownfire is offline
post #2 of 19 (permalink) Old 03-02-2009, 04:38 PM
All done now
Arisley's Avatar
Re: Replacing turbo pedestal o rings
Put a dab of grease on the o-rings, especially the lower ones, to hold them in place. Don't lose the o-ring, on the y-pipe.
Arisley is offline
post #3 of 19 (permalink) Old 03-02-2009, 06:19 PM
PeterB
If you've done injectors you won't break a sweat pulling the turbo. There are lots of write-up's on turbo removal if you wish. Biggest bugger might be the exhaust to turbo flange removal. Many folks find this to be stuborn. I have removed a turbo several times, and had no problem with the flange. Just soaked it with PB Blaster the night before, then woundered what all the discussion was about.
2000 F-250, 4x4 XLT shorty CC, AT, ISSPRO trans/pyro/boost, TTM, SCMT, AFE, HX, 2003 T-stat, Sonax/Tricum, 4 1/2" Donahoe lift with 315/70/R17 tires, 4" MBRP T-304 SS exhaust, Coolant filter
PeterB is offline
post #4 of 19 (permalink) Old 03-02-2009, 08:13 PM Thread Starter
Motownfire's Avatar
Cool, thanks for the heads up. I just watched Maintains turbo removal video, seems pretty simple. I have heard nightmare stories of the exhaust flange removal on the back of the turbo. Are there any sponsors that sell the o rings or just swing by the dealer???
post #5 of 19 (permalink) Old 03-02-2009, 08:40 PM
All done now
Arisley's Avatar
Right here. http://www.dieselorings.com/index.ph...by=DESCRIPTION
Arisley is offline
post #6 of 19 (permalink) Old 03-02-2009, 08:56 PM Thread Starter
Motownfire's Avatar
Grassy ass mi amigo.
post #7 of 19 (permalink) Old 03-03-2009, 12:48 AM
got boost
Send a message via AIM to Lmgrcivic
just swing by the dealer and grab one up there only a couple bucks
01 Black 4dr auto, 118k, BTS trans, RR fuel system, DIY intake, 5in exhaust, CCV, zoodad, non EBV pedestal, high flow outlet, DP-tuner 60hptow, 80hp econo, 100hp per, 120hp race, SS oil crossover line, boost tube, map sensor, IH cps, gauges, RC leveling kit w/leaf springs
94 Civic LS motor turbo'd 11.6 @ 120 14psi stock block
Lmgrcivic is offline
post #8 of 19 (permalink) Old 03-03-2009, 01:07 AM
7.3 Enthusiast
91turbogsx's Avatar
I've always had a problem getting the v-band off the turbo to manifold collector flange. I ended up making a custom bent screwdriver to pop it off after ruining one vband clamp which isn't too cheap from Ford.
Pretty simple job except for the fact that you'll be laying on top of your engine for a little while. Gets a little uncomfortable.
'02 F-350 4x4 Black RC/LB
4" Lift with 35's. OUO Traction Blocks
20x10 Fuel Throttle's
Lots of deleted parts...
Custom fuel system w/ Strictly Diesel RR
Dieselsite Adrenaline HPOP
DI Up-Pipes
DP-Tuned
and more...
91turbogsx is offline
post #9 of 19 (permalink) Old 03-03-2009, 02:07 AM
All done now
Arisley's Avatar
I have an old sofa cushion I use on the top of the motor. Plus my fuel filter cover and bracket are long gone. First thing that disappeared off my motor.
Arisley is offline
post #10 of 19 (permalink) Old 03-03-2009, 12:22 PM
PeterB
Arisley has an excellent point. I use an old colman cloth sleeping bag layed over the engine. To protect the guts. If you have an old packing blanket that would work well also, but get something to lay over the engine. Your belly will love you for it.
Peter
PeterB is offline
Human Verification
