AIH relay - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 02-22-2009, 02:51 PM Thread Starter
AIH relay
I want to ditch mine. No good reason really other than neatening up the engine bay. My AIH is gone, so this thing is useless. I'm pretty sure I can just pull it out, but what about the wires? I don't want them just hanging around in there. Obviously the power out wire is alreay gone, but what about the signal from the PCM? Can I cut it of and cap it? What have you all done with your wires?
Southpaw is offline
post #2 of 13 (permalink) Old 02-22-2009, 03:08 PM
All done now
Arisley's Avatar
Re: AIH relay
Heat shrink, don't cut it off. Just heat shrink and tie it up. That way if you ever need to go back for some unforeseen reason, the wires are still there.
Arisley is offline
post #3 of 13 (permalink) Old 02-22-2009, 04:16 PM Thread Starter
Re: AIH relay
Gotcha, good idea....
Southpaw is offline
post #4 of 13 (permalink) Old 02-22-2009, 04:52 PM
guzzle's Avatar
Re: AIH relay
Doesn't elimination of the AIH end up throwing a soft code without the resistor mod?
Without the relay, there is no way to do the resistor trick.
Bob - 'guzzle'
02 F350 4x4 SRW EC LB Lariat
guzzle is offline
post #5 of 13 (permalink) Old 02-22-2009, 05:47 PM Thread Starter
Re: AIH relay
Yeah mine already throws the soft code, but no SES light. I don't plan on doing the resistor mod cause it doesn't bother me.
Southpaw is offline
post #6 of 13 (permalink) Old 02-22-2009, 07:59 PM
<----My last CT scan
Motownfire's Avatar
Re: AIH relay
What's the resistor mod???
Motownfire is offline
post #7 of 13 (permalink) Old 02-22-2009, 08:29 PM
guzzle's Avatar
Re: AIH relay
It's just putting about 1k resistance from the AIH relay to ground to make the PCM think that the AIH is still there.
Bob - 'guzzle'
guzzle is offline
post #8 of 13 (permalink) Old 02-22-2009, 08:51 PM
ELKHUNTER's Avatar
Re: AIH relay
My AIH solenoid is powering my glowplugs.
Josh
2000 F350 205,000
STAGE II SPLITS 100%
STEALTH SRP1
TYRANT TUNES
38R TURBO
BTS VALVE BODY
WALBRO 392
SCANGAUGE
ISSPRO
MORE STUFF
ELKHUNTER is offline
post #9 of 13 (permalink) Old 02-22-2009, 09:39 PM Thread Starter
Re: AIH relay
Why is your GPR not doing that job?
Southpaw is offline
post #10 of 13 (permalink) Old 02-22-2009, 11:07 PM
got boost
Send a message via AIM to Lmgrcivic
Re: AIH relay
I was thinking about getting rid of mine to but wasnt sure if it would cause any problems
01 Black 4dr auto, 118k, BTS trans, RR fuel system, DIY intake, 5in exhaust, CCV, zoodad, non EBV pedestal, high flow outlet, DP-tuner 60hptow, 80hp econo, 100hp per, 120hp race, SS oil crossover line, boost tube, map sensor, IH cps, gauges, RC leveling kit w/leaf springs
94 Civic LS motor turbo'd 11.6 @ 120 14psi stock block
Lmgrcivic is offline
Human Verification
