7.3L turbo engine loses power/RPM's - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 02-16-2009, 05:48 PM Thread Starter
Question 7.3L turbo engine loses power/RPM's
When holding at steady RPM's either driving or running in park (doesnt matter) it sounds like the engine is releasing air. When it does the engine loses power and the rpm's fall. If I accelerate it goes away until the rpm's hold steady again. Any ideas? ? ? ?
99 SuperDuty is offline
post #2 of 8 (permalink) Old 02-16-2009, 05:57 PM
OBS PSD Owner
Re: 7.3L turbo engine loses power/RPM's
My 96 Powerstroke has the same problem, at lower RPMs (1500 range)when motor is cold, while holding the same throttle position. Push harder and it will speed up and be fine. Can hear the same air sucking noise. Any Suggestions?
7.3fordman is offline
post #3 of 8 (permalink) Old 02-16-2009, 06:07 PM
casper7.3's Avatar
only when cold i'd say the ebp valve is closing in wich case it would be a normal condition
on edit: welome to the nation guys
LUKE
2002 CCLB AUT0 4X4
S&B, DI/PRICOL GAUGES, CCV, ZOODAD, TS CHIP-MATT AT GEARHEAD,
38R, ADRENALINE, SWAMP'S IDM, 4" T/B MBRP
05 CONVERSION, 4 INCH LIFT, 325/65-18 FIERCE ATTITUDE M/T
WILSON 5000 GALAXY DX66
casper7.3 is offline
post #4 of 8 (permalink) Old 02-16-2009, 06:08 PM
Lurker...
Fever's Avatar
EBPV sounds about right...
2003 F-350 Super Duty
Fever is offline
post #5 of 8 (permalink) Old 02-16-2009, 06:26 PM
OBS PSD Owner
Where is the EBPV located and should anything be done to fix this annoying problem?
post #6 of 8 (permalink) Old 02-16-2009, 06:34 PM Thread Starter
my 99 doesnt do it cold. It will do it all the time. It is very annoying. It seems to be stealing power form the truck.
post #7 of 8 (permalink) Old 02-27-2009, 02:25 AM
OBS PSD Owner
Is it a possibility that it could be the wastegate??? Someone heard my truck and said that was what it sounded like
post #8 of 8 (permalink) Old 02-27-2009, 03:22 AM
Harl
Harl's Avatar
Send a message via AIM to Harl
Yep its the EBPV... My 96 did the same thing when I drive it took the power from my truck so I just unlpuged it..
Cody,17
DD-1996 F250 Powerstroke, 5speed, 4x4 ecsb
Mods: GlowShift Gauges-Boost, Pryo, Oil psi and Fuel psi. DIY 6637 Intake, 160/100's, Wildman 6pos, Stage 2 water/meth, D66, TE HPOP, Vailer Clutch, Custom Bars and 5in turbo back....
PT-1995 F350- totaled
Soon to be brought back to a 1992
Harl is offline
Human Verification
