7.3 randomly quits - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 07-28-2013, 12:37 AM Thread Starter
7.3 randomly quits
I have an 03 f350 7.3 the truck starts and runs great then out of nowhere it will quit like you turned the key off. After pulling over it will start up and away we go might run a 100 miles or it might not run for 5 miles. The thing is when you pull over unless you turn the key to off it will not start.
turn the key off fires right up I have replaced cps icp and irp.
Some time I want to associate the quiting when I hit a bump or pothole
not to sure . Could use a little help just today pulling the camper it quit at 70 mph what a ride cant steer or stop w/10,000 camper. it quit 5 times in 20 miles after we got off the interstate. any info would help the thing is that it starts up.
george german is offline
post #2 of 19 (permalink) Old 07-28-2013, 01:11 AM
Re: 7.3 randomly quits
Try a new cam position sensor. Get it from Ford or International.
Matt
Early 1999 F250 4x4 Crew Cab 7.3 liter Lariet
Matt-F350 is offline
post #3 of 19 (permalink) Old 07-28-2013, 01:14 AM Thread Starter
replaced it with one from IH no change
post #4 of 19 (permalink) Old 07-28-2013, 01:54 PM
To properly diaganosis you need a good scanner. Ae is 350$ its a great investment if you plan on owning the truck for any sort of time.
Besides you'll probably waste that trying to fix it by throwing parts at it.
02 F350 CC DRW 4X4.
PHP Hydra with Gearhead, PHP, and NLTD tunes. AIRAID INTAKE, 4" exhaust.
CTS INSIGHT w/ egt, coolant and boost sensors.
FULL FORCE 160/30'S.
RIFFRAFF Hrx & Frx.
Leveling kit, 285's
Van turbo/ 38r hybrid.
barnhartal is offline
post #5 of 19 (permalink) Old 07-29-2013, 12:09 AM Thread Starter
yea your prob right I have the idm out of it now looking for a bad wire no such luck did find that the little breather or vent was missing and there is an open hole in the thing wondering if it can be tested . Anyone have a quiting problem with an idm
post #6 of 19 (permalink) Old 07-29-2013, 12:12 AM Thread Starter
anyone
post #7 of 19 (permalink) Old 07-29-2013, 12:17 AM Thread Starter
my son was driving the truck one time he said that when he slammed the door the truck would quit he claims it did it a couple times
post #8 of 19 (permalink) Old 08-25-2013, 12:05 AM Thread Starter
I think I might have found a problem pcm I think is under the dash next to the e brake
it seems to be loose I was under there pulling on wires I noticed it is just flopping around
tapped on it and the truck quit but I only had it quit once any ideas. was on the interstate and the truck quit pulled over restarted it hit the rumble strip and the thing quit did this about 5 times before I could get back on the road ran like a champ for 300 miles where can I get a pcm and can I get a reman and how much are they
post #9 of 19 (permalink) Old 08-25-2013, 03:02 AM
FL-DIESEL's Avatar
before doing that check and see if the harness bolt isnt loose
2002 7.3 stabbin waggon ... 4in turbo back, cold air, autometer pillar, dp-tuned...more to come, feel free to make donations
FL-DIESEL is offline
post #10 of 19 (permalink) Old 08-25-2013, 07:36 AM
As FL said - make sure the bolt on the engine side of the firewall is tight. There should be a black plastic box that the PCM is enclosed in on the inside as well. It supports/protects the PCM - held to the kick panel with a couple of small bolts.
hydro man is offline
Human Verification
