fuel heater - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 10-16-2007, 12:39 AM Thread Starter
Tedzz's Avatar
Send a message via MSN to Tedzz
Question fuel heater
This mornin' while lettin the truck warm up, It died. I checked and sure enough fuse #30 was blown again. No WTS light when tryin to start it up. after burnin up 3 more fuses,came in here and read about 200 posts about good ole #30.I unplugged the fuel heater thingy from the fuel bowl. Replaced #30 and she fired right up nice and smooth. Now here is the question,,,,,how important are these fuel heaters and can they be replaced or fixed or just forgotton about???? In this neck of the woods we can get into sub-zero temps. last winter we saw -14 degrees F. What y'all think??
Ted
'99 F350 Type 6
'85 F450 Type 6
Tedzz is offline
post #2 of 11 (permalink) Old 10-16-2007, 03:39 AM
All done now
Arisley's Avatar
Re: fuel heater
Ted,
I have heard, that if you have a good glow plug system, it will do good without it. A new heater is over a hundred bucks when I checked. I disconected mine last fall the first time it went below 50. Never missed it in our frigid Texas winters. Like I said, if your glow plug system is working good, and you are running good winter blend, I think you will be fine. IIRC, the fuel bowl heater helps with gelling.
Arisley is offline
post #3 of 11 (permalink) Old 10-16-2007, 02:42 PM
Haul_n_horses2's Avatar
Re: fuel heater
Originally Posted by Arisley View Post
Ted,
I do not think it will do anything to prevent gelling but it might keep the fuel in the bowl warm enough so water that is frozen in the fuel will melt and separate without plugging the filter.
2002 F350 Lariat CC 4x4 4.10 DRW, with "the ultimate towing setup!": Nov 30, 1999 engine with Fluidampr, Melling LPOP, 910 springs and ARP headstuds, DP-Tuner, DI regulated return, AC singles with 80% over EDM nozzles, BTS dual HPOP, H2e, Spearco 6.0 IC and BTS tranny .
Haul_n_horses2 is offline
post #4 of 11 (permalink) Old 10-17-2007, 06:12 PM
OEM Moderator
Tom S's Avatar
Re: fuel heater
I have a new in the package fuel heater if you need one. PM me.
Tom
Tom S is offline
post #5 of 11 (permalink) Old 10-17-2007, 07:24 PM
<-- it's like that
Re: fuel heater
My truck ran funny with the fuel bowl heater unplugged. Most say it doesn't affect their truck, but I plugged mine in due to how it ran.
Curtis
2002 F-250 PSD
Gambling with 250/200's on PMR's.
478hp/851tq on Haller's dyno - 7/28/12
Your connection to the
Pocket is offline
post #6 of 11 (permalink) Old 10-18-2007, 01:47 AM Thread Starter
Tedzz's Avatar
Re: fuel heater
Tom,, PM sent--thanx
'99 F350 Type 6
'85 F450 Type 6
Tedzz is offline
post #7 of 11 (permalink) Old 10-19-2007, 03:31 PM
X Racer
Racer X's Avatar
Re: fuel heater
What the heater does is melt any waxy gel that will plug injectors. Diesel can gel in very cold temps. I think there is enough heat once the engine has some warmth, the heater isn't needed. Most do without the heater fine.
I replaced mine anyway with the Super Duty element on Joats website. From International it's about $45.
Contact Racer X USA for Fully Custom built transmissions, Torque Converters & Valve Bodies.
Racer X is offline
post #8 of 11 (permalink) Old 11-02-2007, 01:18 PM Thread Starter
Tedzz's Avatar
Re: fuel heater
UPDATE-------Thanx to Tom S. for gettin me a new fuel heater. I went and got what I needed to modify the fuel bowl per Joat's website. Took off the fuel bowl last night, and son-of-a-***** if it didn't just drop right in without any modification to the bowl!!!! The hardest part was gettin the wire lead turned to hook back up. Any way,, THanx Tom and all for the help. Ted
'99 F350 Type 6
'85 F450 Type 6
Tedzz is offline
post #9 of 11 (permalink) Old 11-02-2007, 03:12 PM
OEM Moderator
Tom S's Avatar
Re: fuel heater
Glad it was a nice easy repair. Might be a great spot to post up that International part number.
Tom
Tom S is offline
post #10 of 11 (permalink) Old 11-03-2007, 02:30 AM Thread Starter
Tedzz's Avatar
Re: fuel heater
Now that I have dug it outa the trash,,,,,
International Part no 1831196C92 (made in the USA)
great idea Tom,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, Ted
'99 F350 Type 6
'85 F450 Type 6
Tedzz is offline
Human Verification
