Serpentine Belt - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 01-22-2009, 04:31 AM Thread Starter
Construction Babysitter
wooner's Avatar
Serpentine Belt
How long can you run the engine without the serpentine belt in place? A couple of seconds? A couple of minutes? Not at all?
Dave
99.5 F250 Lariat : 6" lift on 37" Toyo MT's, DP Tunes, Built Transmission, Airbags, AIH Delete, 38R, Banks Big Head, CCV Mod, Sinister Regulated Return, IH bellowed up pipes, AFE Stage II, ISSPro Performax gauges, Scan Gauge, Casserly Stage I's, T-500 HPOP, Swamp's IDM
wooner is offline
post #2 of 7 (permalink) Old 01-22-2009, 04:36 AM
Re: Serpentine Belt
you run it as long as you want
KliffBar is offline
post #3 of 7 (permalink) Old 01-22-2009, 04:38 AM Thread Starter
wooner's Avatar
Re: Serpentine Belt
Thanks. Looking for a real answer though.
Dave
wooner is offline
post #4 of 7 (permalink) Old 01-22-2009, 11:24 AM
All done now
Arisley's Avatar
Re: Serpentine Belt
I wouldn't want to run it longer than a than a minute or so. The temp gauge will go up really fast. Just long enough to eliminate a pully from making a noise.
Arisley is offline
post #5 of 7 (permalink) Old 01-22-2009, 01:45 PM
casper7.3's Avatar
Re: Serpentine Belt
just a few min...keep in mind if you must move it no powersteering or brakes.
LUKE
2002 CCLB AUT0 4X4
S&B, DI/PRICOL GAUGES, CCV, ZOODAD, TS CHIP-MATT AT GEARHEAD,
38R, ADRENALINE, SWAMP'S IDM, 4" T/B MBRP
05 CONVERSION, 4 INCH LIFT, 325/65-18 FIERCE ATTITUDE M/T
WILSON 5000 GALAXY DX66
casper7.3 is offline
post #6 of 7 (permalink) Old 01-22-2009, 03:13 PM Thread Starter
wooner's Avatar
Re: Serpentine Belt
Thanks fellas
Dave
wooner is offline
post #7 of 7 (permalink) Old 01-22-2009, 04:33 PM
Busy Busy
Marty's Avatar
Re: Serpentine Belt
And no alternator charging your batteries... which is no where near as important as the water pump not turning though.
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
Human Verification
