Shop labor hours to swap out a complete 03 7.3 long block - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 06-10-2013, 08:31 PM Thread Starter
Herb03 7.3's Avatar
Anyone have access to or know what the labor hours are for swapping out a complete 03 7.3? Ford shop hours and what the actual hours should be? My truck is in the dealership and am told I need to replace my engine. Thinking of buying a supposedly very reliable complete 01 long block from yard and having them pull it and just drop it in. I know there are a lot of Mods that would be great while its out but first I can't do much of the work myself and I sure don't have the money for them to do it. Might consider a few things but money is tight. Sh... I don't really have the money for the current repairs. Just need a starting point then will go from there. Want to make sure they aren't raping me to bad and maybe I can try and keep them in check. Already got a bill of about $800 for pulling the valve covers, checking a couple injectors and doing a compression test. Was in the process of getting new injectors but cancelled that when they told me I had one bad cylinder with half the compression as all the others.
Herb03 7.3 is offline
post #2 of 12 (permalink) Old 06-10-2013, 08:54 PM
the stryker god
Re: Shop labor hours to swap out a complete 03 7.3 long block
you need to take the truck to a backyard mechanic. the dealership is gonna eat you alive. i guarantee it would be over 2,000 dollars. my buddy who owns a used car lot has a guy who will change them for 300.
bruce51d is offline
post #3 of 12 (permalink) Old 06-10-2013, 09:11 PM
jbrixen's Avatar
F250 Super Duty,F350 Super Duty,V8,Diesel,Automatic Trans w/Air Cond
Includes: Transfer fuel and electrical assemblies, replace engine mounts, adjust idle speed and ignition timing. DOES NOT include transfer of manifolds, valve covers, oil pan, timing cover or water pump. NOTE: For bare engines - refer to Long Block Assembly -
R&R. 19.6 hours
this is using napa pro link, witch is Mitchell
jbrixen is offline
post #4 of 12 (permalink) Old 06-10-2013, 09:16 PM Thread Starter
Herb03 7.3's Avatar
Yea Bruce I know. Unfortunately here on the Eastern Shore of Maryland there just aren't many good Diesel mechanics that I can find. Not saying they aren't here. Twice in a row now I have been screwed by back yard mechanics and both referred. But I'm willing to try one more time once I talk with them and feel more comfortable. Yea you just about hit that one on the head. They quoted me 20 hrs labor at $2300 to do either a Factory reman or a complete used long block from a yard. I know the yard one should be less cause they don't have to pull a few parts of mine to put on it but haven't haggled with them yet over a few $$$. 20 hours just seems a lot. especially since they have already started. Hoping someone knows of a good knowledgable but yet fair mechanic Crap I'll bring the beer and man the grill and even give a hand where ever I can. I'm just not a lone wolf hands on engine kinda guy.
post #5 of 12 (permalink) Old 06-10-2013, 09:22 PM Thread Starter
Herb03 7.3's Avatar
Thanks jbrixon, and if they get it done is 15 they still charge me the 20. Long block going back in has everything I believe. So what you think? Still 19.6?
post #6 of 12 (permalink) Old 06-10-2013, 09:23 PM
the stryker god
You might go down to the regional subforum and find someone on here who is in MD or nj or de. Personally I'd take it to Marty's before I gave the dealership a dime
bruce51d is offline
post #7 of 12 (permalink) Old 06-11-2013, 12:18 AM
Old Yeller, REBORN
kilapapipa's Avatar
I just finished a job like this. Probably had 40 hours in it with help from my dad. You have to remember the whole front end needs to come off.
REBORN 20 Over on 3/2/11- Pics in gallery- 2000 F250, Auto, 38r, Full Force 238cc/100%, TE 17* hpop, DP F5,HI,60T,80E,120R,140A, Studs and 910's with DI PR's, JW VB in 2nd stock tranny, Walbro 392, Bellowed, In-Tank, Pre-Pump, boost fooler, and RR. Air Dog, SS cover, 6.0 TOC,4" straight piped and guages, 6637, coolant filter, 4" Lift on 33's.
kilapapipa is offline
post #8 of 12 (permalink) Old 06-11-2013, 01:52 AM
I just had mine out of my 2001, new pan and back in ready to start in 10 hours, its not a bad job. Find a good mechanic that you trust and have them do it.
Racer72 is offline
post #9 of 12 (permalink) Old 06-12-2013, 05:18 PM
Do you know what a long block consist of? 20 hours to pull an engine, change all the parts over on to a new long block and reinstall sounds pretty good. Its not an easy job. The labor rate sounds like it may be high though...depending on your area average labor rate is about 60-90 an hour with an average of what we see @ $85.00 x 20 Hours = $1700.00. So I can only imagine they are adding in fluids, hoses, gaskets etc..
Here is a picture of our ATK 7.3 Diesel engine long block for those who do not know what it consist of..you have to swap all external parts over including EFI, Covers, Accessories etc on top of pulling and reinstalling.
ATK High Performance Engines
"When in doubt, throttle out!"
2002 F250SD 4x4
4" Magnaflow Turbo Back Exh
BEANS
Zoodad Mod
Riff Raff 6637 Intake
Edge CTS Monitor
Notalent is offline
post #10 of 12 (permalink) Old 06-13-2013, 07:30 AM
Yes even if they get the job done in 15 hrs they still charge you the 20. That's how they make up for all the jobs that took 4 hrs but the book said they can only charge 2.
It costs a ton of money to buy all those tools that let's them shave a couple hours off a big job or a couple of minutes off a small one.
02 F350 CC DRW 4X4.
PHP Hydra with Gearhead, PHP, and NLTD tunes. AIRAID INTAKE, 4" exhaust.
CTS INSIGHT w/ egt, coolant and boost sensors.
FULL FORCE 160/30'S.
RIFFRAFF Hrx & Frx.
Leveling kit, 285's
Van turbo/ 38r hybrid.
barnhartal is offline
Human Verification
