P0264 code... Cylinder 2 injector circuit low - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 01-06-2009, 11:17 PM Thread Starter
Hoosier daddy!
Ramblin'_Man's Avatar
I just replaced the UVCH's and I'm still getting the P0264 code when I do a buzz test or a KOEO test. What could be the possible causes? A bad solenoid? Bad #2 injector? The engine runs fine right now, no missing that I can notice.
2001 PSD F250
Born 4/01 in KY USA,
4x4, 3.73, Ext. Cab, Shortbox...
ITP RR, CCV, Tymar Intake, Airdog, DP tuner
Ramblin'_Man is offline
post #2 of 11 (permalink) Old 01-07-2009, 12:20 AM
diesel tech
diesel71's Avatar
Re: P0264 code... Cylinder 2 injector circuit low
you could have high resistance in the injector solenoid. did you do a cylinder contribution test? a bad wire in the engine wire harness can cause that too,pin out the harness to eliminate that.
diesel71 is offline
post #3 of 11 (permalink) Old 01-07-2009, 01:51 AM Thread Starter
Hoosier daddy!
I ran the contribution test with AE and it performed successfully.
2001 PSD F250
post #4 of 11 (permalink) Old 01-07-2009, 04:19 AM
All done now
Arisley's Avatar
Mike, I know it is kind of time consuming, but try swapping the injector into another hole, see if the problem follows the injector.
Arisley is offline
post #5 of 11 (permalink) Old 01-07-2009, 05:07 AM
What else?
smokyred's Avatar
Check the resistance of that solenoid, and if it's the same as the others, swap it with another to see if the code follows.
If not, start pinning out the harness.
Dave
smokyred is offline
post #6 of 11 (permalink) Old 01-07-2009, 10:53 PM Thread Starter
Hoosier daddy!
Ok guys... Thanks for the ideas. Since this isn't causing me problems right now, I think I'll wait for spring(warmer weather ) and then try swapping injectors/solenoids and see how things go from there.
Dave, can the solenoids be swapped without pulling the injector? Or will I have to go the route Andy mentioned, pulling the whole injector?
2001 PSD F250
post #7 of 11 (permalink) Old 01-07-2009, 11:37 PM
fueled by Colecovision
golfer's Avatar
Garage
you can swap a solenoid without removing the injector.
chances are it is not a bad solenoid, though.
We have an inductance meter, with which we use to check the solenoids... and we have maybe seen 4-5 bad solenoids in the past 5-6 years...tens of thousands of injectors worth.
It is possibly a bad solenoid, and maybe worth swapping on another solenoid for comparison, but we have seen high internal resistance, on the MOSFET drivers within an IDM create similar "bad solenoid" scenarios...so maybe try another IDM if the solenoid swap doesn't fix things.
...or it could be that the armature to solenoid clearances are not 'correct' on that particular injector creating a higher current flow through the IDM...
HEUI's are such lovely little things...
take care~
Dave
golfer is offline
post #8 of 11 (permalink) Old 01-08-2009, 01:03 AM Thread Starter
Hoosier daddy!
I had heard that the chance of an injector solenoid going bad was fairly slim. If I can swap one without pulling the injector, I will try that first. Actually, I think I'll just ohm all the solenoids first and see how they compare. What is the desired ohmic value of the injector solenoids?
2001 PSD F250
post #9 of 11 (permalink) Old 01-08-2009, 01:11 AM
What else?
smokyred's Avatar
I can't recall correctly what the ohm value is of a good solenoid, sorry.
But the single bad solenoid that I've found was all black and melted underneath when I took it off, externally it looked fine.
Dave
smokyred is offline
post #10 of 11 (permalink) Old 01-08-2009, 01:15 AM
mandkole's Avatar
I think all of my old AAs were about 3.2-3.3 ohms...
2000 F250 CCSB-- GT4294R, 250/100s, Dahl/Fuelab, PHP, scan gauge, stock 17* pump
1994 F250 4x4 SC (sold)
1997 F250 CCSB 2wd (sold)
mandkole is offline
Human Verification
