OIL LEAK - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 01-01-2009, 10:13 PM Thread Starter
OIL LEAK
I have a 2001 f250 with a oil leak I cant pinpoint. The pass. side down the back of the motor is wet and it is making it all the way down to the starter and to the bottom of the tranny. If I run the truck hard(trailer behind it, driving like its not there) there is little oil spots on the rear diff and on the front of the trailer. It is not like this always though, if you look on top of the motor the valve cover harness plug is wet with oil in that area. I leave very little drops when you park it but it is annoying.
semomotorsports is offline
post #2 of 16 (permalink) Old 01-01-2009, 10:20 PM
Genius, when I drink
ditch_dawg's Avatar
Re: OIL LEAK
Check out this thread.....
http://powerstrokenation.com/forums/...ad.php?t=20658
'03 F250 CC
"Beer is proof God loves us and wants us to be happy" Benjamin Franklin
Originally Posted by golfer View Post
blip the throttle, and you just changed your "HPOP" oil
put that on youtube
ditch_dawg is offline
post #3 of 16 (permalink) Old 01-01-2009, 10:21 PM
ironworker25's Avatar
Re: OIL LEAK
Originally Posted by ditch_dawg View Post
2000 F250
Maual 4 wheel with warn premium hubs
4" superlift
315/75r16 Goodyear Wrangler MTR
Straight piped
203 stat and billet housing
Mag-Hytec rearend cover
autometer sport comp guages
170,000 miles
ironworker25 is offline
post #4 of 16 (permalink) Old 01-01-2009, 10:24 PM Thread Starter
Re: OIL LEAK
My valley is dry for the most part, I have never left a spot on the ground bigger than a quarter, when you pull hard like I do it looks like little dots all over the rear diff. I was wondering if maybe my valve cover is leaking or crankcase vent problems?
post #5 of 16 (permalink) Old 01-01-2009, 10:44 PM
ditch_dawg's Avatar
Re: OIL LEAK
Might be your turbo pedestal? Check your bolts on your valve cover to make sure they are tight. I had a couple of loose ones when I swapped out my glow plugs. Could be something as simple as that too.
'03 F250 CC
put that on youtube
post #6 of 16 (permalink) Old 01-01-2009, 10:50 PM Thread Starter
Re: OIL LEAK
have you heard anything about the crankcase vent issues, I heard you can reroute and hook up a hose to a catch can in the back of your truck. I have never had the valve covers off, but I will check them. It is only wet in the middle of the pass. side were the plug in is and on the back of the head.
post #7 of 16 (permalink) Old 01-01-2009, 11:30 PM
ditch_dawg's Avatar
Re: OIL LEAK
There are a lot of people that run a CCV mod. I haven't done that yet. You can do a search and I'm sure you'll find plenty good info.
I haven't heard of that plug leaking before. Thankfully, that one is pretty easy to get to. Give that area a good cleaning and run the snot out of it and see if you can trace the leak back. Or you can change the o-ring in that plug just for giggles.
'03 F250 CC
put that on youtube
post #8 of 16 (permalink) Old 01-01-2009, 11:32 PM Thread Starter
Re: OIL LEAK
I have cleaned the area and run the snot out of it and it will be wet like it is now. I cant tell, I think ccv or valve cover, I havent heard of ether giving a problem though.
post #9 of 16 (permalink) Old 01-03-2009, 04:04 PM
JimTJr's Avatar
Re: OIL LEAK
CCV is driverside Valve cover. Passenger side is the starter. If you clean it, and drive it, but don't drive it a long ways between checking, you can find it. It just takes patience. Clean it drive it a couple blocks, then pull into a parking lot, look good with a mirror and flashlight.... ect...
Since you say the plug on the valve cover is wet too on the passenger side, man, I can't imagine the Intercooler tube having THAT much oil in it... no way.
It almost certainly has to be coming from the cover I guess, if there is NO oil in the valley,,,, Try snugging the VC bolts a tad,,, (NOT much) and they are supposed to be even, so maybe take them all down 1/4 to 1/2 turn? (UNLESS you find one or two much more loose than the others)
*48* Jim T. 2011 F-350 Lariat, CC, LB, SRW. White Platinum Metallic Tricoat. Black leather seats, I probably wont have*PMS,, with this one, at least no major attacks of it!
JimTJr is offline
post #10 of 16 (permalink) Old 01-04-2009, 03:05 AM Thread Starter
Re: OIL LEAK
I will try that, I know I have hundreds on spots on the ground where I park my truck and let it ldle and warm up. I just cant stand it leaking, the motor was always dry. The only thing I have done to the motor is water pump, fan clutch, ldler and tensioner. I had a high pitch whisle pulling a trailer hard. The oil is right there at the boot on the inter cooler tube. If it is in the tube, hows it get there other than blow by? I can remove the oil cap and have very little blow by, its been the same since I bought the truck.
Human Verification
