7.3 injector problem or bad fuel?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 11-01-2008, 12:41 PM Thread Starter
crazycruz257's Avatar
O.K. I have a 2000 Ford rollback tow truck with a 7.3 Powerstroke. I just replace the injectors about a month ago and the truck was running sweet. I fueled up thursday night out of town. Come friday the truck had a very strong fuel smell when running. By friday night 1/2 to 3/4 of a tank of fuel later the truck was smoking real bad and sounded like it was missing at idle. On the highway it runs like a top. Shut the truck off for a few minutes and it has a catch when you turn it over. Like the injector is stuck open and dripping fuel in the cylinder. We put it on the scanner and it says the #8 injector is bad. Now my questions are: Did I get some bad fuel and clog the injector to where it is stuck open? Or Do I maybe have a defective injector that is shorted and staying open? And how could I tell? If it is clogged and stuck open is there a way to clean it? Thanks in advance.
Later Cruz
crazycruz257 is offline
post #2 of 5 (permalink) Old 11-01-2008, 12:46 PM
All done now
Arisley's Avatar
Re: 7.3 injector problem or bad fuel??
Welcome to the Nation!
Not real up on injectors, others are and will be on shortly.
I think I would start by pulling the injector and looking at o rings.
Arisley is offline
post #3 of 5 (permalink) Old 11-02-2008, 02:38 AM
What else?
smokyred's Avatar
#8 is driver's side-rear, check the wiring and if it's OK, pull the injector out and see if the o-rings are OK. If they are good you may have an internal injector problem.
Dave
smokyred is offline
post #4 of 5 (permalink) Old 11-02-2008, 03:47 AM
POWERSTROKER's Avatar
Swap #8 with 2,4, or 6, if the problem stays at #8 you have a wiring issue, if the problem follows #8 injector replace it.
Early 1999 (4/98) 7.3, Automatic, f-250 superduty, 4x4, crewcab, shortbed.
CCV Mod
knn intake
banks exhaust
banks power elbo
banks turbo housing
big head waste gate-disconnected
Tuning by
4 gauge pod with DiPricol pyro, boost, trans temp, HPOP
POWERSTROKER is offline
post #5 of 5 (permalink) Old 11-04-2008, 02:32 AM
What else?
smokyred's Avatar
I should have said that, lol. Also after you find and fix the problem, replace the o-rings on the injectors you pulled out, they are not generally re-usable.
Dave
smokyred is offline
Human Verification
