Glow plug control module - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 03-02-2013, 03:14 PM Thread Starter
FSJPat's Avatar
I have been getting glow plug codes for 3 and 4 for awhile, so I replaced all the glow plugs (I used motorcraft plugs). I am getting codes for 3 and 4 again,. I pulled everything apart again and made sure that all the connections were tight (I'm also getting a lot of noise through the stereo since the replacement).
My truck is a California truck, so it has a module for the glow plugs instead of a relay. Could the codes and noise be a sign that the module is going bad?
2000 F250 7.3/ZF-6 SC/SB 2WD PHP tunes, MBRP 4" exhaust, 6637 intake, Hutch Mod, Frx, Hpx
FSJPat is offline
post #2 of 6 (permalink) Old 03-03-2013, 01:45 AM
Sponsor
Justin@DP-Tuner's Avatar
Re: Glow plug control module
Have you checked/replaced the UVCH?
Justin Bochmann
Like us on
Justin@DP-Tuner is offline
post #3 of 6 (permalink) Old 03-03-2013, 05:23 AM
Horsepower Enthusiast
sho669's Avatar
Yes the module can go bad, replace them pretty often.
I always measure the ohms of each glow plug by disconecting the harness above the valve cover and testing the pins (outer two on either side of the connector). Should see about an ohm of resistance, if you have one thats way off (higher) then thats your issue. This also rules out UVCH issues since the readings will be higher if the plug is backed out.
If you resistances are good then you have a bad module.
03 CCSB King Ranch 4X4 6.0, IDP Xstreet, Muffler delete. 13.90@94.627
00 CCSB, ZF6, 2WD. RIP 1-22-12
06 Mitsubishi Evolution IX SSL, LR 2.0, TS EFR9180, E85, 4 slicks and a chute...maybe some other stuff
69 Camaro, awaiting turbo LSX and chassis work
sho669 is offline
post #4 of 6 (permalink) Old 03-03-2013, 07:38 PM Thread Starter
FSJPat's Avatar
I looked at it when I pulled the valve covers off, nothing seemed wrong with it. I will probably check that next after the module.
I'll give that a shot next. Thanks everyone for the help.
FSJPat is offline
post #5 of 6 (permalink) Old 03-31-2013, 12:26 PM Thread Starter
FSJPat's Avatar
So I finally got a chance to check things out again. I tested the resistance of the pins in the connector on the valve cover, got 4 ohms for each of the glow plugs. Brand new plugs, don't think that is the problem. I think the 4 ohms is from my cheap meter and not being able to get a good connection on the pin. They were all consistent, though.
Tested the harness that plugs into the connector with the key on, got 11.9 volts at each one, so I think the GPCM is good.
I think at this point my UVCH is the problem, something is not making a good connection. Am I right in my thinking?
So my next step is ordering new UVCHs. Should I replace the valve cover gaskets along with the harnesses (they don't leak)?
FSJPat is offline
post #6 of 6 (permalink) Old 03-31-2013, 04:24 PM
jtgf250's Avatar
They are your gasket. Shouldnt leak. Make sure your grounds are good also if getting static on your radio. 4 ohms doesnt sound good to me and .5v loss is enough for them to not work. I havent messed with a cali truck so not sure about the module and how it hooks up.
2003 F-250 CCLB 7.3L
4" lift and PMF traction bar/block setup running 35s on 20x12s. Intake, exhaust, PHP Hydra w/ Gearhead tunes, gauges
2005 F-350 CCLB 6.0L
6" lift on 20x10s and 37s, studded, deleted, Powermax and Livewire with Quicktricks tunes, exhaust, intake (Wife's Truck)
jtgf250 is offline
Human Verification
