1997 Ford F350 7.3 will not start - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 04-02-2012, 12:38 AM Thread Starter
Engine shut down with no warning, I have replaced the fuel pump, and the crank sensor. The truck still will not start. It will start on either and then immediately shut down. Can anyone make a suggestion or have any idea what the problem may be?
vallery47 is offline
post #2 of 10 (permalink) Old 04-02-2012, 12:42 AM
Young'n
powerstrokeracing's Avatar
Re: 1997 Ford F350 7.3 will not start
IPR? check the wiring to it as well. seen the wires break before. easy on the ether
powerstrokeracing is offline
post #3 of 10 (permalink) Old 04-02-2012, 12:43 AM Thread Starter
Hate to sound like an idiot, but where is the IPR located?
post #4 of 10 (permalink) Old 04-02-2012, 12:48 AM
Quitter
DMDP's Avatar
IPR is on the hpop. Did you check your fuel bowl heater fuse?
Jon
96 Fummins 2.6 puller
'10 f250 ccsb 6.4. Sold
'15 f350 6.7 dually on order!
DMDP is offline
post #5 of 10 (permalink) Old 04-02-2012, 12:50 AM
Quitter
DMDP's Avatar
Fuse #22 in the fuse panel under the hood
Jon
DMDP is offline
post #6 of 10 (permalink) Old 04-02-2012, 12:52 AM Thread Starter
Checked the fuse, its OK. In the process of the checking the IRP. Thanks!
post #7 of 10 (permalink) Old 04-02-2012, 01:27 AM Thread Starter
Woops typo, IPR
post #8 of 10 (permalink) Old 04-03-2012, 12:28 AM
tbolt's Avatar
might check in the obs section. I'm not familiar with those minor diff from our superduties. Good luck.
Have you scanned it??
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
tbolt is offline
post #9 of 10 (permalink) Old 04-03-2012, 12:37 AM
middlemanjw's Avatar
what he said take it apart and clean it or replace pry stuck open!
it on the back side of the hpop!
middlemanjw is offline
post #10 of 10 (permalink) Old 04-16-2012, 04:29 AM
ASE CERTIFIED TECH
WOW!! I had the same problem and took a month to figure it out. First thing is to take off your fuel filter and check if there is correct amount of fuel in it. I can almost bet you have a clogged fuel line like mine. I changed the same things you did on my 97. The problem was the fuel tank auxiliary switch on frame rail before tank was fully clogged with black mudd to the main feed line. I just bypassed mine to front tank only and was a $20 fix. Rubber fuel line,barbed fitting and hose clamps and it was fixed! You can take it off and clean it but for me the switch was bad and only ran the front tank anyway. Man hope this help you and good luck!!
f0rdracing is offline
Human Verification
