Changed oil '01 7.3 Now no start & HPOP is full? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 02-29-2012, 10:06 PM Thread Starter
Changed the oil in a 01 7.3 without filling the new oil filter. It started and ran for 10 second then started to bog down and almost died then picked back up and ran fine let it run for a few minutes and shut it down for the night. Next day i went to start the truck and it started fine ran for 10 seconds bogged down and died and wont restart. So today before i tried to start it i checked the HPOP and its full and I put 2 new batteries in it for giggles and tried it again after sitting all night and it cranks and hits infrequently like its trying to start but wont. What could it be?
DENALI is offline
post #2 of 10 (permalink) Old 02-29-2012, 10:12 PM
User Error
buck90's Avatar
Re: Changed oil '01 7.3 Now no start & HPOP is full?
during the time you did get it to run did you happen to notice where your oil pressure gauge was reading?
buck90 is offline
post #3 of 10 (permalink) Old 02-29-2012, 10:31 PM
95powersmoker's Avatar
How much oil did you put in the case?
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #4 of 10 (permalink) Old 02-29-2012, 10:32 PM Thread Starter
No i didnt but while cranking it has great oil pressure
DENALI is offline
post #5 of 10 (permalink) Old 02-29-2012, 10:33 PM Thread Starter
15 quarts
DENALI is offline
post #6 of 10 (permalink) Old 02-29-2012, 11:45 PM
TURBO LIT 'N' THAT WAS IT
powerstrokin7.3's Avatar
take the filter off amd make sure it has oil in it
03 SCSB (TOTALED)
00 ccsb zf6, 4" exhaust, 6637, ts chip w/php tunes, tinted glowshift gauges, ats ported housing,RR, leveled, ccv mod, pp mod, zoodad, intake heater delete, ebpv delete, WW2, t-500, South Bend clutch, more to possibly come
powerstrokin7.3 is offline
post #7 of 10 (permalink) Old 03-01-2012, 12:26 AM
my S.I.L. truck did this exact same thing, it ended up being the IDM... He fired it up, move it out of the gargae into the driveway and shut it off. Later that day, hge went to pull the truck back up in the garage and it would not start.
I had him build a hose/gauge setup to check rail pressure, ok. Checked fuel pressure, ok. had him put an outlet tester on the injector wire, no spark.
Brought a known good used IDM up there with me, installed it and the truck fired right up. Ended up ordering a modded one from Swamps...
PoorMansCat is offline
post #8 of 10 (permalink) Old 03-01-2012, 03:18 PM Thread Starter
Anyone else have any ideas? Is it a bad idea to give it a few short squirts of starting fluid while cranking to try and get it going?
DENALI is offline
post #9 of 10 (permalink) Old 03-01-2012, 03:37 PM
Old Yeller, REBORN
kilapapipa's Avatar
REBORN 20 Over on 3/2/11- Pics in gallery- 2000 F250, Auto, 38r, Full Force 238cc/100%, TE 17* hpop, DP F5,HI,60T,80E,120R,140A, Studs and 910's with DI PR's, JW VB in 2nd stock tranny, Walbro 392, Bellowed, In-Tank, Pre-Pump, boost fooler, and RR. Air Dog, SS cover, 6.0 TOC,4" straight piped and guages, 6637, coolant filter, 4" Lift on 33's.
kilapapipa is offline
post #10 of 10 (permalink) Old 03-02-2012, 04:12 AM
tbolt's Avatar
starting fluid is a no no. Always fill the filter. Check the hpop res in the morning before trying to start it.
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
tbolt is offline
Human Verification
