99 7.3 Bad fuel Mileage - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 23 (permalink) Old 02-22-2012, 04:27 PM Thread Starter
I need some help. I am a mechanic, but not a diesel mechanic. I bought a 99 F250 a year ago and I am not getting the fuel mileage that everyone says I should be getting. In the city, on the highway, loaded or unloaded, towing or not, I have not gotten over 14mpg.I am hearing everyone says that they are getting in the 16-20 range. I do not drive hard at all. I do have a superchip programmer on it but even at the stock setting, or the fuel saving setting, it is no better. Here is what I have done so far:
-Checked every sensor I could find for correct resistance, temperature, etc.
-Checked for exhaust leaks and restrictions up-pipes and all.
-Checked for boost leaks
-Checked the turbo for excess play
-Changed fuel and air filters
-Filled the fuel bowl with seafoam
-Ran several bottles of cleaner through the fuel system
-Checked for dragging brakes
-Checked boost pressures
-Checked fuel pressure -57psi
-Removed and cleaned exhaust back pressure valve
-No smoke in the morning when first started, if there is some it is so faint you can not see it.
- Very little black smoke when you really get on it
-Tires are 32's on stock wheels
The only thing I have not done to date is checked the injectors or injector o-rings.
I don't know what else to do. Help please.
AaronWWood is offline
post #2 of 23 (permalink) Old 02-22-2012, 05:15 PM
Old Yeller, REBORN
kilapapipa's Avatar
Re: 99 7.3 Bad fuel Mileage
How many miles on it?
Might do a compression check.
REBORN 20 Over on 3/2/11- Pics in gallery- 2000 F250, Auto, 38r, Full Force 238cc/100%, TE 17* hpop, DP F5,HI,60T,80E,120R,140A, Studs and 910's with DI PR's, JW VB in 2nd stock tranny, Walbro 392, Bellowed, In-Tank, Pre-Pump, boost fooler, and RR. Air Dog, SS cover, 6.0 TOC,4" straight piped and guages, 6637, coolant filter, 4" Lift on 33's.
kilapapipa is offline
post #3 of 23 (permalink) Old 02-22-2012, 05:52 PM Thread Starter
170K miles. I know it is possible, but I know the original owner and the services have been kept up religiously. I will look into it, any other ideas?
'99 F250 2WD 7.3 Crewcab LB 170k miles Leveling Kit with 285/75/16 mud tires on stock wheels
post #4 of 23 (permalink) Old 02-22-2012, 06:06 PM
black smoke boys
i have same trk im getting same as u
ryanoneil79 is offline
post #5 of 23 (permalink) Old 02-22-2012, 06:07 PM
black smoke boys
sorry mines 4wd
post #6 of 23 (permalink) Old 02-23-2012, 05:07 PM
deeno's Avatar
When I had my 2000 psd it got around 14 to 15 empty and around 9 to 10 when pulling around 5000lb. That was with a 60hp tune from my predator tuner. I have never know a 7.3 to get 20mpg. My 6.0psd did everytime though.
deeno is offline
post #7 of 23 (permalink) Old 02-23-2012, 06:11 PM
Village Idiot
southmike's Avatar
Dieselsite boost leak detector..good tool
What size tires, how much air in each,gears all have impact.
I got 15.7 stock prob 17 on a great day now.
Best guess is 12 towing.
Bte useless meter says 19'7 now, I just use it to let me know better or worse.
Tunes throw them off.
southmike is offline
post #8 of 23 (permalink) Old 02-23-2012, 07:00 PM
Have you accounted for your tire size being larger than stock, which will make your speedo/odometer read low?
HillbillyDeluxe99 is offline
post #9 of 23 (permalink) Old 02-26-2012, 05:34 PM
i have an 01 f350 cc,lb,drw,4wd now with the 7.3 and she gets about the same as you, and previously i had a 2000 f250 ec,lb,srw,4wd 7.3 that got the same as well, however the 97 cc,lb,srw,2wd, 7.3 that i had would get just about 20 on the highway. Tire size could account for some, changing the gears out might help you, but it can be pricey on a 4wd
drunken_sailor_man is offline
post #10 of 23 (permalink) Old 02-26-2012, 07:07 PM
biostroke1
biostroke1's Avatar
I feel your frustration. My first 01 cclb 4x4 stock hieght got 16-19mpg. My 02 cclb 4x4 gets about 12-15 both city and highway 33" tires and 4" lift. I know the lift and tires dont help but I cant see a 5mpg improvement if it was at stock hieght. Im not calling anyone a liar but I find it real hard to believe some of the guys who claim 20+ mpg running 37's w/ big lifts. If they are, I'd love to see what they are doing different. My first 01 cclb 4x4 got way better mpg's then my current 7.3 even after I lifted it. But not 20mpg. I dont know why this is.
biostroke1 is offline
Human Verification
