7.3 Fuel Lift pump - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 11-19-2011, 07:22 PM Thread Starter
7.3 Fuel Lift pump
Went to start the '96 this morning and turns over but won't fire. Last several weeks ago I had a small fuel leak showing up in the valley. A it is around 10 degrees here. Are there any tricks to diagnosing a the lift pump in the valley?
James96 is offline
post #2 of 4 (permalink) Old 11-19-2011, 08:08 PM
Hood Rich
CTC DEEZUL's Avatar
Send a message via AIM to CTC DEEZUL
Re: 7.3 Fuel Lift pump
hook a ful pressure gauge to the port on side of fuel bowl
NWI Coal Rollers Association
Local 444- Rolling Coal Teamsters
via Beans Toonz
DI SS Up-Pipe
GTP38R
CTC DEEZUL is offline
post #3 of 4 (permalink) Old 11-19-2011, 10:45 PM
Need more info.
What's it doing when its not starting?
Btw you posted in the wrong section.
02 f250
countryboyrob is offline
post #4 of 4 (permalink) Old 11-21-2011, 06:35 PM Thread Starter
Pulled the filter out and gray and hazy but didn't look like typical gelling. When I turned it over and then opened the bowl it was pressurized but even after doing it again the pump didn't fill it. Our fuel here in Minnesota has 15% biodiesel so that is why I am still thinking maybe geling. When the lift pump fails does it go cold turkey or just reduced pressure explaining air pressure in bowl and no fuel?
James96 is offline
Human Verification
