02 cc has a vibration @ 40 to 55mph? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 60 (permalink) Old 05-15-2011, 09:36 PM Thread Starter
biostroke1
biostroke1's Avatar
Hey guys, I was wondering if someone could help me figure out what the heck is causing this vibration that starts around 40mph and fades a little after 50mph? It shakes the tuck enough to cause any image in the rear view mirror to distort. There is no noise like a squeak or grind like a bad u-joint. Ive heard that carrier bearings do go bad. There is some play in the carrier, is there supposed be? My truck has 123k. All suggestions are greatly appreciated. Thanks in advance
biostroke1 is offline
post #2 of 60 (permalink) Old 05-15-2011, 09:58 PM
tree trimmer's Avatar
Re: 02 cc has a vibration @ 40 to 55mph?
carrier bearing, out of balance wheel, tierods, ball joints, wheel bearings. because its speed sensitive, ill lean toward a tire
2010 f350 srw lariat
tree trimmer is offline
post #3 of 60 (permalink) Old 05-15-2011, 10:00 PM
diesel fiend
florida 6.0's Avatar
Is is a long bed ?
05 F350 9" 4 link , 37's , 4.56 's php and gearhead tuned
florida 6.0 is offline
post #4 of 60 (permalink) Old 05-15-2011, 10:05 PM Thread Starter
biostroke1
biostroke1's Avatar
About a month ago the truck would shake whenever I start off from a light or stop sign but that went away.
post #5 of 60 (permalink) Old 05-15-2011, 10:05 PM Thread Starter
biostroke1
biostroke1's Avatar
Yes its a long bed
post #6 of 60 (permalink) Old 05-15-2011, 11:13 PM
diesel fiend
sounds like a carrier bearing
post #7 of 60 (permalink) Old 05-15-2011, 11:23 PM Thread Starter
biostroke1
biostroke1's Avatar
Yea, There is a little slop in mine but I was't sure if that was normal or not.
post #8 of 60 (permalink) Old 05-16-2011, 03:46 AM
Need a ride.
Strokerstooge's Avatar
Just had my second carrier bearing go out, a slight vibration and a low howling noise, first was a rubbing sound on tight turns. Their cheap enough to swap out and hopefully its your problem.
03 F-250 7.3 XLT CC SB Auto 38R, S-B Intake, 4 inch MBRP Duals, Regulated Return, J Wood VB, DP Tuner, Isspros 3 Pillar, Terminator Scan Gauge, DS Coolant Filter, HPX
Strokerstooge is offline
post #9 of 60 (permalink) Old 05-16-2011, 04:02 AM Thread Starter
biostroke1
biostroke1's Avatar
Should I do the u-joints @ the same time since the drive shaft will be out?
post #10 of 60 (permalink) Old 05-16-2011, 07:27 PM
Construction Babysitter
wooner's Avatar
do you have a lift?
Dave
99.5 F250 Lariat : 6" lift on 37" Toyo MT's, DP Tunes, Built Transmission, Airbags, AIH Delete, 38R, Banks Big Head, CCV Mod, Sinister Regulated Return, IH bellowed up pipes, AFE Stage II, ISSPro Performax gauges, Scan Gauge, Casserly Stage I's, T-500 HPOP, Swamp's IDM
wooner is offline
Human Verification
