P1247 code what does it mean???? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 05-04-2011, 11:02 PM Thread Starter
I have a 2001 7.3 with a edge evo cts and the diagnostic reader said that I have a P1247 code and idk what it means I could use some help.
Diesel_Kidd222 is offline
post #2 of 5 (permalink) Old 05-04-2011, 11:30 PM
Busted Knuckles
PSDEng's Avatar
Re: P1247 code what does it mean????
That is a MAP code. Check for leaks, I think that code is a low boost code. Do you have a tuner/chip?
'97 Powerstroke SCLB:
i have a couple friends that went balls deep in wyotech and when they got out they couldn't poor piss out of a boot if you put the directions on the sole
PSDEng is offline
post #3 of 5 (permalink) Old 05-04-2011, 11:35 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Turbo boost pressure low...
Check for leaks, check for connection at the MAP sensor, check the up pipes...
Do you have gauges?
01 F-250 SC PSD,280k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
CSIPSD is offline
post #4 of 5 (permalink) Old 05-08-2011, 07:43 PM Thread Starter
Noo I don't have gauges but I have a programmer an edge evo cts and today it popped up more codes a p0733 in stage 2 and I wouldn't go into reverse so I switched it back to stock and it went into reverse then. Then on the way home in stock setting it wouldn't change into secong gear it popped up a p0732.
post #5 of 5 (permalink) Old 05-08-2011, 09:49 PM
CSIPSD's Avatar
Man, did you sink your truck in a lake???
Check the tranny harness at both the Fire wall and at the tranny. Sounds like a loose or corroded wire...
Joe
CSIPSD is offline
Human Verification
