7.3 sudden problem - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 25 (permalink) Old 04-24-2011, 08:09 PM Thread Starter
7.3 sudden problem
I have a 03 250 7.3 When I went to start the ole truck this am ,started just fine like it always does then all the sudden it starts running real ruff like its not running on all cylinders,cab shaking plus the cel comes on ....no smoke at all.
If I let it run a little wile it will even out for a few seconds then it ill go back to runny like crap again.Weird thing is its been running just fine,pulled the boat with it yesterday and not even a hiccup.
Can you guys give me a idea of where to start to look,would appreciate it ?
Best I can think must be some kind of sensor....duhh thats the best I can do.Did have the cps replaced when the recall came out and the alternator replaced last yr. .
Forgot to mention its all stock.
Power Stroke Ford F-250 2003 Ext,Cab.Stock
pwrstrdude is offline
post #2 of 25 (permalink) Old 04-24-2011, 08:12 PM
<----Nice headlights!!!
TylerDurden's Avatar
Re: 7.3 sudden problem
CPS again. Or hpo problems.
Check fuses first. Check connections second. Get a scanner third if there is a cel.
2000 F250 4x4 cc/sb. 6" w/37's and some other stuff.
TylerDurden is offline
post #3 of 25 (permalink) Old 04-25-2011, 02:14 AM
All done now
Arisley's Avatar
I am guessing UVCH.
Arisley is offline
post #4 of 25 (permalink) Old 04-25-2011, 03:15 AM
OBS finding my way
jake2far's Avatar
Get the code, it will help with the diagnosis.
Jim
1996 OBS Crewcab, Shortbed, 4x4, Automatic Transmission, Baby Swamps, Adrenaline HPOP, SuperDuty Electric Fuel Pump conversion, Quick Turbo Housing, 6 Position Chip, 3" Down Pipe, 2 Disc Locking Converter, Intercooler
jake2far is offline
post #5 of 25 (permalink) Old 04-25-2011, 03:47 AM
Marc's Avatar
Originally Posted by Arisley View Post
I am guessing UVCH.
I second this, i would be pulling the valve covers to check the harnesses. A scanner to get the code/do a buzz test would also be nice.
The other thing ive seen with trucks is that because of neglected mainanence, oil leaks, or burning oil, if the oil level gets right down to the pickup tube so it draws some air by it too (about 6 quarts low) they will draw air and the oil will foam. As the oil warms and the level raises just a little tiny bit, it wont draw the air anymore and they will clear up.
NHRDA Region 2 Race Director
Marc is offline
post #6 of 25 (permalink) Old 04-25-2011, 04:54 AM
tbolt's Avatar
UVCH is my bet. Been there.
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
tbolt is offline
post #7 of 25 (permalink) Old 04-25-2011, 05:28 PM
OBS Addict
7.3psd97444's Avatar
UVCH FTW
Hope ya get it figured out.
-Jordan-
97 SCLB 7.3 Handshaker
Valair Clutch, only the best.
TS 6 Position Tyrant Tuning
S&B, MBRP, Isspro, Mag-Hytec, 1.00 A/R Exhaust housing, HPX
Full sound system: Kicker-Kenwood
BILLET BADGES
Dick Cepek DC-2's/Duratracs
On-Board Air
Few cosmetics
PSA # 269
7.3psd97444 is offline
post #8 of 25 (permalink) Old 04-25-2011, 05:49 PM
JesseM's Avatar
FWIW..
If it comes back with the IDM code, check the wires OVER the valve cover too. My truck did this once to me over the winter, then went away. Then not until just last week and wouldnt go away. I was thinking the wires under the valvecover too like most guys say, but it turned out the harness OVER the valve cover was sagging and chafing and shorting out. As soon as I picked up the wires, problem solved.
"New" Diesel owner, have wanted one since I was about 10 yrs old. 2000 F-350, EC/SB, Lariat, DynoMax pipes, AEM intake, Banks Big Head, DiabloSport tuned for now
..List of things to buy: Wicked Wheel, Valve Body, 6.0 Intercooler and Tranny cooler, undecided on tuner...
JesseM is offline
post #9 of 25 (permalink) Old 04-26-2011, 02:23 AM Thread Starter
Hey... Thanks for all the info.I dropped the truck off today to get a diagnostic done.I will post when I get the results tomorrow .
On thing I forgot to mention, I was getting cel (battery) off and on 2 weeks early and then it went away to never return.I checked the batteries that are 3 weeks old,the alt is new too.
Anyway ,what may I ask is a UVCH ? It sounds expensive
post #10 of 25 (permalink) Old 04-26-2011, 02:30 AM
Super Hauler!
Super_Hauler's Avatar
under valve cover harness, your idm send a signal to your injectors and glow plugs through these. Usually they just melt or the clip breaks or loosens up and you get a bad connection. could have saved your self some money and did it yourself, its stupid easy! My little girl almost has it down.
Super_Hauler is offline
Human Verification
