broken glow plug... help please - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 04-22-2011, 08:58 PM Thread Starter
Hi guys, I've been trying to search this problem, but not finding the same problem that I have. I was removing the glow plug and it snapped, leaving all the threads in the hole, then tried using an easy out, it seemed to start moving but then snapped that, now I have both stuck in the glow plug hole and no way to get them out. Is there any way to do this without removing the head? I really can't do the head removal myself, and can't afford to put that much into this truck.
thanks in advance for any help.
swampjeep is offline
post #2 of 12 (permalink) Old 04-22-2011, 09:00 PM
Re: broken glow plug... help please
Would you be able to try using a small pick? Maybe even a small punch and a hammer? Anything is worth a shot.
02 f250
countryboyrob is offline
post #3 of 12 (permalink) Old 04-22-2011, 09:10 PM Thread Starter
it is in solid, it does not move with a hammer tap, there are no threads sticking out to grab, and all the threads are still in the head
post #4 of 12 (permalink) Old 04-22-2011, 09:13 PM
What plugs are they?
02 f250
post #5 of 12 (permalink) Old 04-22-2011, 09:28 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Try and get the easy out out...
Then soak it in BP blaster for a while, fill the whole cavity up with it...
Then try the easy out again.
01 F-250 SC PSD,280k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
CSIPSD is offline
post #6 of 12 (permalink) Old 04-22-2011, 10:13 PM
Freak'n know it all
gottagofast's Avatar
put it back together and run it with 7 glowplugs...... anything you do from this point causes you to run the chance of either damaging the head or dropping something into the cylinder..... either way the head would have to come off and you said you can't handle that.....
there are PLENTY of diesels on the road with one or more bad glowplugs and the owners don't even know
99.5 350 crewcab dually 4x4
stage 1 singles, PHP tunes, banks bighead,
autometer gauges,
, South Bend HD clutch, Gen 2 wicked wheel, AIS intake system.
gottagofast is offline
post #7 of 12 (permalink) Old 04-22-2011, 10:28 PM
All done now
Arisley's Avatar
I have 3 bad ones right now on my truck. In order to fix it right, the head needs to come off. Just remember it's there and if you ever pull the head, address it then.
Arisley is offline
post #8 of 12 (permalink) Old 04-22-2011, 11:44 PM
Old Yeller, REBORN
kilapapipa's Avatar
If it doesn't work, run without it. What climate zone are you in? I have a buddy here in Wyo. that runs on 7 because he broke one off in #8 and he is fine.
REBORN 20 Over on 3/2/11- Pics in gallery- 2000 F250, Auto, 38r, Full Force 238cc/100%, TE 17* hpop, DP F5,HI,60T,80E,120R,140A, Studs and 910's with DI PR's, JW VB in 2nd stock tranny, Walbro 392, Bellowed, In-Tank, Pre-Pump, boost fooler, and RR. Air Dog, SS cover, 6.0 TOC,4" straight piped and guages, 6637, coolant filter, 4" Lift on 33's.
kilapapipa is offline
post #9 of 12 (permalink) Old 04-22-2011, 11:55 PM
stackedstroker's Avatar
This is what I would do if I was in yours shoes, but you really need to get the easy-out out of there because down the road it might vibrate out and tear something up!!
My .02 cents
1999.5 F 350 crew cab dually 4x4, 330,000mi, TS 6 position, Edge monitor, Itp regulated return, sinister boost inhilator, ccv mod, afe stage ll, s475, 300cc 200% hybrids, Adrenaline HPOP, Airdog 150, Jasper class 1 full built tranny, triple disc Torque converter, AIH delete, 4" exhaust.
stackedstroker is offline
post #10 of 12 (permalink) Old 04-23-2011, 12:10 AM
Next time run the truck to temperature first. It loosens the carbon on the GP's.
Personally, I'd put it back together. 7 glow plugs will get you by.
ddillenger is offline
Human Verification
