6.0 no start when hot. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 12-24-2010, 03:12 AM Thread Starter
you want some of this?
smorris's Avatar
Doesnt want to start when hot. Seems to be fine otherwise. Sometimes will shut off, and then no re-start. After cooling it will fire back up just fine. No apparent external leaks of any kind, runs great when running, plenty of fuel.
Any ideas? Being that I'm a 7.3 guy......well
2000 f-350 cc lb dually 4x4, BTS transmission
7.85@ 90 mph on MT mud tires and 8,000 #
coming soon--97 cc lb 4x4
smorris is offline
post #2 of 10 (permalink) Old 12-24-2010, 03:17 AM
co04cobra's Avatar
Re: 6.0 no start when hot.
Sounds like a STC fitting problem if its a 05 up truck. Otherwise you will need to datalog some stuff to go deeper
00 f250 some stuff done always more to do.
Best advice I have seen on here "If you cant afford to build it right you certainly cant afford to build it twice"
co04cobra is offline
post #3 of 10 (permalink) Old 12-24-2010, 03:19 AM Thread Starter
smorris's Avatar
2005 truck. That the quick connect fitting I saw in the 6.0 sticky? Will this be an external leak, or internal?
smorris is offline
post #4 of 10 (permalink) Old 12-24-2010, 03:20 AM
FNG
Dave's Avatar
STC fitting or ICP sensor.
If its STC the leak could go either way.
Put it on the scanner
Dave G
06 F250 Lariat 4x4 leveled on 35s
4 inch flowmaster exhaust
Bulletproof diesel egr delete.
Bulletproof diesel FICM
Performance Machine & Manufacturing Coolant Filter Kit
ECM and FICM tuned by Bill at PHP SCT tunes from Gearhead, Innovative and Wildman
Dave is offline
post #5 of 10 (permalink) Old 12-24-2010, 03:21 AM Thread Starter
smorris's Avatar
10-4 , thanks for the quick replies!
smorris is offline
post #6 of 10 (permalink) Old 12-24-2010, 12:23 PM
40 lug nuts
Snake's Avatar
HPOP, branch tube, and/or STC fitting.
BULLETPROOF DIESEL
Biofuels Technologies
1A Auto
2005 F-250
Snake is offline
post #7 of 10 (permalink) Old 12-24-2010, 01:07 PM
sounds like the fittings feeding the rails and not the STC fitting...
hhrecovery is offline
post #8 of 10 (permalink) Old 12-24-2010, 09:22 PM
"6.0's the way to go"
Dummy plugs in the ends of the high pressure oil rails under valve covers, Ford has updated plugs with better o rings. If it was a failed stc it would not start period!
Arp headstuds
Sinister full egr delete
Mbrp cat delete
Updated stc fitting
Updated dummy plugs
Latest ficm calibrations
Sct custom tunes 75-165hp
Harley6.0boy is offline
post #9 of 10 (permalink) Old 12-25-2010, 02:56 PM
40 lug nuts
Snake's Avatar
Mine did.
BULLETPROOF DIESEL
1A Auto
2005 F-250
Snake is offline
post #10 of 10 (permalink) Old 12-25-2010, 03:19 PM
it's an 02 05 08
turbodiesel_02's Avatar
could be an stc or ipr.id lean more towards stands pipes or dummy plugs.you can put air to the icp sensor and maybe hear a leak,everything is going to be internal.
2002 ext. cab lwb 4x4 7.3
05 front 08 rear conversion
4in lift,forged rod motor,tunes by tsd,bts trans,6.0 transcooler,6 autometers to watch,studs,springs,push rods,238cc hybrids,itp reg return,stealth hpop,tsd custom fuel system and sump,an so on
6.0's pay the bills and 6.4's soon..
turbodiesel_02 is offline
Human Verification
