Installed new turbo. Truck now dies while driving. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 02-09-2017, 02:34 AM Thread Starter
Garage
This is my first post so Please let me know if I'm in the wrong place! So my 2006 f250 6.0 turbos went out on me about 2 months ago. After letting the truck sit I finally bought a power max garret turbo (used not brand new but worked fine). After installing the turbo myself my truck at first started up and ran good but it didn't produce the amount of boost I expected. I let it sit the night and the next evening after work I came home and started the truck. Started fine besides it having to crank a little longer than usual but as I drove it I noticed it barely made any boost at all then it died on me while driving. I got it to start again after many tries and having to hold down the gas pedal to get it going. I continued you drive some and it did this again and again every couple minutes. It's also leaking oil from somewhere on the turbo. I honestly put the turbo on in a rush. Do you guys think I just didn't tightened down something correctly and that's causing the Low boost, dying, and oil leak?
Graveytrain1994 is offline
post #2 of 9 (permalink) Old 02-09-2017, 02:45 AM
Ruben72's Avatar
Garage
Re: Installed new turbo. Truck now dies while driving.
Look the turbo supply line and drain tube
Sent from my XT1650 using Tapatalk
Ruben72 is offline
post #3 of 9 (permalink) Old 02-09-2017, 02:49 AM
Trust me, I got this...
Cummins Junkie's Avatar
Garage
Welcome! To answer your question, if you rushed and inadvertently did a shoddy job on the install, you should probably go back and inspect it very carefully, probably even take it back out and check for damage and look at the seal on the top of the turbo, and the tube leading out of it on the underside. Do that, and then report your results. Hope this helps!
Shoulda bought a Cummins. May or may not have a cummins swap in the works.
1997 7.3L XLT, 4x4, 5spd, 307k, TS chip, 6637 filter, 4" straight piped dual exit
If you got a D60 or tan superduty/OBS seats PM me.
Cummins Junkie is offline
post #4 of 9 (permalink) Old 02-09-2017, 03:11 AM
Master BS'er
jamiesaun's Avatar
Make sure the turbo is in good shape. Impeller should be tight radially and axially. Check for leaks at the up pipe and compressor side. Leak is either at the feed tube and drain tube. Also make sure the solenoid is working.
Jamie.
p.s...I'm pretty frickin awesome!
jamiesaun is offline
post #5 of 9 (permalink) Old 02-09-2017, 11:15 AM Thread Starter
Garage
Thanks for the advice! I know I had a really hard time with the tube on the underside getting it to sit in place. And the line coming out of the top seemed to be ozzing a little bit of oil but I tightened it down more it didn't seem to leaking that much. But under my turbo there is definitely a decent amount of oil
post #6 of 9 (permalink) Old 02-09-2017, 11:15 AM Thread Starter
Garage
I will break back into it and report back
post #7 of 9 (permalink) Old 02-11-2017, 03:51 PM Thread Starter
Garage
I've checked my oil drain tube and and the oil line on top of the turbo is all good. The truck will start up and run but when I put it in drive and try to go the turbo will just start cutting out then the truck dies.
post #8 of 9 (permalink) Old 02-11-2017, 06:20 PM Thread Starter
Garage
Truck is having a really hard time starting now
post #9 of 9 (permalink) Old 02-17-2017, 01:22 AM
Big dumb redneck
6speedSD's Avatar
Garage
Turbo issues won't make a truck not crank or run. Need a way to monitor the ole girl. We need to see some data. Being a 06, I'm going to guess a high pressure leak....possibly STC fitting or standpipes.
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
Human Verification
