Cat delete - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 02-02-2017, 02:06 PM Thread Starter
6.ohh-so-slow
Cat delete
Warranty won't let me modify my exhaust. Any other ways to lower eggs and make me turbo louder??
6slowpowerstroke is offline
post #2 of 19 (permalink) Old 02-02-2017, 02:17 PM
ShatMan! NanaNanaNanaNana
Turd-250's Avatar
Re: Cat delete
welcome! i'm assuming that custom tuning will be a problem with the warranty too? i believe injector timing would be important, but if you are have stock tuning and stock injectors right now, there shouldn't be much to worry about...
a side note: look up part # 350wbext on ebay. this will fit in place of the cat on a stock 6.0 exhaust. direct bolt-on. no irreversible modification needed. and yes, it can make the turbo a bit more noticeable lol
Turd-250 is offline
post #3 of 19 (permalink) Old 02-02-2017, 02:24 PM Thread Starter
6.ohh-so-slow
Re: Cat delete
Yes, sadly no engine modifications either, or it would be bulletproofed. I have Gages, and turbosaver, and haven't yet looked at the bottom studs to see if it has been studded. I will look up the part, thank you!
post #4 of 19 (permalink) Old 02-02-2017, 02:29 PM
Turd-250's Avatar
Re: Cat delete
no problem! i've installed two of them so far.
oh yeah another thing people say make their turbo more noticeable (from in the cab) is simple soundproofing their interior! kind of a neat side effect, being as the drone is lessened. i'll be replacing body mounts soon, and will have the seats and carpet out. i'll do as much of the cab as i can.
Turd-250 is offline
post #5 of 19 (permalink) Old 02-02-2017, 02:29 PM Thread Starter
6.ohh-so-slow
I be able to reinstall the stock car without ruining anything correct? Basically this test pipe just bolts on and then comes back off so you can replace the stock piece?
post #6 of 19 (permalink) Old 02-02-2017, 02:31 PM
Turd-250's Avatar
Re: Cat delete
exactly! take a look under your truck and look at the flange on the upstream side and the clamp on the downstream side. then remove the CAT's hanger, you won't need that with the test 'd e l e t e' pipe
Turd-250 is offline
post #7 of 19 (permalink) Old 02-02-2017, 02:31 PM Thread Starter
6.ohh-so-slow
Re: Cat delete
And sorry about all of the typos😂
post #8 of 19 (permalink) Old 02-02-2017, 02:33 PM
Turd-250's Avatar
Re: Cat delete
no prob, i've seen way worse! the worst is when people don't use punctuation while telling a long winded story about how their truck started acting up lol
Turd-250 is offline
post #9 of 19 (permalink) Old 02-02-2017, 02:34 PM Thread Starter
6.ohh-so-slow
Re: Cat delete
Okay, that's actually exactly what I was thinking of, because I didn't want to do any permenant changes!! Just sold my 99' and got the 03'. Time for the "delete" pipe, my lift to go back on, and then as soon as I can get an sct tuner.
post #10 of 19 (permalink) Old 02-02-2017, 02:35 PM Thread Starter
6.ohh-so-slow
Re: Cat delete
Yeah, then it's near impossible to read and understand the problem😂
Human Verification
