Time to build a monster - Page 4 - PowerStrokeNation : Ford Powerstroke Diesel Forum
 3Likes
post #31 of 33 (permalink) Old 02-15-2017, 02:51 PM
410customs's Avatar
Re: Time to build a monster
Dang that's what I meant I know right where that car is
I used to live in Georgetown back in 93 I worked at Loveland
That Camaro has been there for years!!
1997 CCLB 7.3, ZF5, 4x4, 4.10, brought back from the dead
2001 Excursion 7.3, auto, 4x4, 3.73, new to us freight train family hauler
I build custom trucks and off road toys in my private shop located in Crawlorado
410customs is offline
post #32 of 33 (permalink) Old 02-15-2017, 06:53 PM Thread Starter
Master BS'er
jamiesaun's Avatar
Originally Posted by 410customs View Post
that lifts looks sweet! HAHAHAHA everything gets lifted here in CO
Fabtech makes good stuff. Two guys in a garage started Fabtech back in the day = good for them
Body lift = taller mounts, or "pucks" (often hockey pucks were used to lift the body) are used on top of the cab mounts to raise the whole cab up 2-3"
Body lifts are cool because they allow you to run larger tires. They are pretty cheap to purchase and they only raise the cab, so the center of gravity is only effected by the weight of the cab going up from the frame. Problem with body lifts is when you get to 3" or more you have to extend things like steering shaft, wiring, brake lines. Also they are kinda ugly when not finished (leave gaps) and they make the engine appear small under the hood. I try not to use them, but have used them to make room for larger tires (to complete a lift)
Larger tires are how we get ground clearance and traction, basically the goal.
Drop brackets, simply drop the diffs, control arms, and suspension parts down from the frame. Like what you installed. Sometimes they come with extensions for the upper balljoint = no way jose. Any type of steering extension or ball joint extension = cheap and scrary I do not install these type lifts at my shop. Instead I would fab a new steering shaft or whatever. Only drop bracket lifts with taller knuckles will get installed here (More $$$ because Fabtech, Superlift actually have to cast a new knuckle) Drop brackets for leaf springs or sway bars work fine...but again any lift that raises the entire frame/drivetrain and cab effects the center of gravtiy by pushing all that weight higher in the air. Drop bracket lifts do not really get you any more wheel travel or a better ride. But they do allow for larger tires and in some cases a much longer strut/shock = improved ride, but a taller COG
Long travel = this would be the type of suspension I am into, This would be longer control arms and CV axles, actually moving the wheel away from the frame. Wider = better. Wider = more wheel travel, we call it "cheater travel" Long travel suspensions do not always raise the vehicle, but they often have adjustable ride heights (threaded body coil over shocks) so you can pick whatever height you need to clear your tires. These are the big $$$$ lifts that will actually improve the ride of your vehicle and make it more capable off road.
Larger tires = more traction contact patch, More travel = keeps tires on the ground, this is what I am after when I build a truck. Wider is better, more travel and a lower COG will keep you moving forward off road.
They all have their place, most street queens use a bracket type lift and combo of body lift to stuff huge tires
Jeeps, Rangers, yotas and Broncos will usually have some sort of long travel and increased width lift on them if they are serious about off road, no body lift.
My Bronco II uses a 1/2" body drop (still stuffed a 5.0L V8 drivetrain in there), I run fiberglass front fenders so I can keep a low COG and still fit 35-37" tires. I then built a custom 5" lifted 4x4 TTB suspension, 9" wider then a stock truck, with 14" of wheel travel = bronco II go off road.
Sweet, thanks for the info dude. That makes perfect sense.
Edit: Ya never are done learning are ya?
Jamie.
p.s...I'm pretty frickin awesome!
jamiesaun is offline
post #33 of 33 (permalink) Old 02-15-2017, 07:02 PM
410customs's Avatar
hell no
I learn alot from my stepsons and I taught them all I know, my customers always have these great ideas about their projects also... Two heads are way better then one, especially in the shop!
youtube has revolutionized the way we share ideas and info...so many shortcuts and cool tools to discover
The minute you think you have it all figured out is the same moment you become a close minded fool
best tool in the shop is your ears
Human Verification
