Time to build a monster - Page 3 - PowerStrokeNation : Ford Powerstroke Diesel Forum
 3Likes
post #21 of 33 (permalink) Old 02-15-2017, 01:15 AM
Big dumb redneck
6speedSD's Avatar
Garage
Re: Time to build a monster
That's not terrible in my opinion, considering what most queerbaits are going for now. 10" lift with 26x14 rims and 40's. Every time i see one I immediately think of a donk.
Lipka101 likes this.
2005 F350 CCLB Dually
Studded, deleted
5" straight piped
155/30's
KC Stage 1.5
Reg return
Beans sump to the stock pump
BPD FICM
6speedSD is offline
post #22 of 33 (permalink) Old 02-15-2017, 01:37 AM
Moderator
Sbluke55's Avatar
Ifs is independent front suspension. Chevys look like someone gave them a wedgie through the fender wells.
I personally like lifted trucks.
01 f-250, Standard
Sbluke55 is offline
post #23 of 33 (permalink) Old 02-15-2017, 01:41 AM
Moderator
Sbluke55's Avatar
this is my truck.
01 f-250, Standard
Sbluke55 is offline
post #24 of 33 (permalink) Old 02-15-2017, 02:56 AM Thread Starter
Master BS'er
jamiesaun's Avatar
Originally Posted by Sbluke55 View Post
this is my truck.
See, that one looks fine, it doesn't look unnatural. The Chevy looks like one of those old Tonka toys or something.
Jamie.
p.s...I'm pretty frickin awesome!
jamiesaun is offline
post #25 of 33 (permalink) Old 02-15-2017, 01:02 PM
410customs's Avatar
that lifts looks sweet! HAHAHAHA everything gets lifted here in CO
Fabtech makes good stuff. Two guys in a garage started Fabtech back in the day = good for them
Also, ya lost me on body vs brackets. I've seen some lifts that just bolt brackets to the existing parts like knuckles and sway bars to gain the clearances. Then I've seen some that incorporate new parts like bigger knuckles, or control arms. I am not familiar with a body lift.
Body lift = taller mounts, or "pucks" (often hockey pucks were used to lift the body) are used on top of the cab mounts to raise the whole cab up 2-3"
Body lifts are cool because they allow you to run larger tires. They are pretty cheap to purchase and they only raise the cab, so the center of gravity is only effected by the weight of the cab going up from the frame. Problem with body lifts is when you get to 3" or more you have to extend things like steering shaft, wiring, brake lines. Also they are kinda ugly when not finished (leave gaps) and they make the engine appear small under the hood. I try not to use them, but have used them to make room for larger tires (to complete a lift)
Larger tires are how we get ground clearance and traction, basically the goal.
Drop brackets, simply drop the diffs, control arms, and suspension parts down from the frame. Like what you installed. Sometimes they come with extensions for the upper balljoint = no way jose. Any type of steering extension or ball joint extension = cheap and scrary I do not install these type lifts at my shop. Instead I would fab a new steering shaft or whatever. Only drop bracket lifts with taller knuckles will get installed here (More $$$ because Fabtech, Superlift actually have to cast a new knuckle) Drop brackets for leaf springs or sway bars work fine...but again any lift that raises the entire frame/drivetrain and cab effects the center of gravtiy by pushing all that weight higher in the air. Drop bracket lifts do not really get you any more wheel travel or a better ride. But they do allow for larger tires and in some cases a much longer strut/shock = improved ride, but a taller COG
Long travel = this would be the type of suspension I am into, This would be longer control arms and CV axles, actually moving the wheel away from the frame. Wider = better. Wider = more wheel travel, we call it "cheater travel" Long travel suspensions do not always raise the vehicle, but they often have adjustable ride heights (threaded body coil over shocks) so you can pick whatever height you need to clear your tires. These are the big $$$$ lifts that will actually improve the ride of your vehicle and make it more capable off road.
Larger tires = more traction contact patch, More travel = keeps tires on the ground, this is what I am after when I build a truck. Wider is better, more travel and a lower COG will keep you moving forward off road.
They all have their place, most street queens use a bracket type lift and combo of body lift to stuff huge tires
Jeeps, Rangers, yotas and Broncos will usually have some sort of long travel and increased width lift on them if they are serious about off road, no body lift.
My Bronco II uses a 1/2" body drop (still stuffed a 5.0L V8 drivetrain in there), I run fiberglass front fenders so I can keep a low COG and still fit 35-37" tires. I then built a custom 5" lifted 4x4 TTB suspension, 9" wider then a stock truck, with 14" of wheel travel = bronco II go off road.
1997 CCFB 7.3, ZF5, 4x4, 4.10, baby swamps, TS6, RSK
2001 Excursion 7.3, auto, 4x4, 3.73, freight train family hauler, collecting parts for suspension lift
2000 E350 7.3, auto 2wd, 3.73, toy hauler camper conversion...researching 4x conversion
SEVEN POINT THREE LEAKER
410customs is offline
post #26 of 33 (permalink) Old 02-15-2017, 01:14 PM
Moderator
Sbluke55's Avatar
Yeah almost everything is lifted. Even cars. It doesnt look like it but that lift is 4" with 37" tires.
01 f-250, Standard
Sbluke55 is offline
post #27 of 33 (permalink) Old 02-15-2017, 01:36 PM
410customs's Avatar
[IMG][/IMG]
post #28 of 33 (permalink) Old 02-15-2017, 01:38 PM
Moderator
Sbluke55's Avatar
This thing is parked next to the interstate for all to see.
01 f-250, Standard
Sbluke55 is offline
post #29 of 33 (permalink) Old 02-15-2017, 01:47 PM
410customs's Avatar
is that in Idaho Springs?
We have a lifted el camino around here on 40's same dude owns a bright red Lambo kit car (fiero) they look like red neck heaven parked next to each other
makes me want to drive over the lambo with the camino
post #30 of 33 (permalink) Old 02-15-2017, 01:48 PM
Moderator
Sbluke55's Avatar
Close, George town.
01 f-250, Standard
Sbluke55 is offline
Human Verification
