Im running a Quadzilla Adrenaline on my 06 with a 24 valve cummins swap. Im trying to find the right ignition on fuse to tap into, the ignition source on the quadzilla backfeeds as a turbo timer when the feature is turned on. Fuse #45 is 10a run/start, will that one work? I tried the customer access fuse and it keps on my ac and radio but shut off the motor. Tried the ignition wire coming from the pcm abd it kept the engine running but ac and radio didnt work and I got a TDC fault message on the dash.
So basically, how are turbo timers made for an 05-07 wired up?
Thanks
Thanks
