Body Mounts - OEM Rubber, Polyurethane, Hydraulic??? - Page 3 - PowerStrokeNation : Ford Powerstroke Diesel Forum
 3Likes
post #21 of 33 (permalink) Old 11-22-2016, 04:47 PM Thread Starter
Informiticus Whoricus
Turd-250's Avatar
Re: Body Mounts - OEM Rubber, Polyurethane, Hydraulic???
this one lol
Edited: you know better
Turd-250 is offline
post #22 of 33 (permalink) Old 11-22-2016, 08:29 PM Thread Starter
Turd-250's Avatar
lol!
Turd-250 is offline
post #23 of 33 (permalink) Old 11-22-2016, 08:42 PM
Moderator
Sbluke55's Avatar
About once a month you have to test the waters don't you?
01 f-250, Standard
Sbluke55 is offline
post #24 of 33 (permalink) Old 11-22-2016, 08:48 PM Thread Starter
Turd-250's Avatar
Turd-250 is offline
post #25 of 33 (permalink) Old 11-22-2016, 10:26 PM
wackyman9's Avatar
Anyone remember the hockey pick body lifts?
-2008 Job #3 F250 CCSB 4x4
-Mishimoto Aluminum Radiator
-Peak Fleet Charge Purple Coolant
-SCT X4 Babysitter
-17" XD Addicts
-285 General Grabber AT2's
-Power Service White in the Tank
-Moog Tie Rods and Drag Arm
-Drilled and Slotted Rotors
-GearBoxZ DPF-R 4.0
-Flo-Pro DOC/DPF delete
-MPD CCV Kit
wackyman9 is offline
post #26 of 33 (permalink) Old 11-22-2016, 10:28 PM
Administrator
Zmann's Avatar
I remember them well
i didn't go that route but I had a chevy luv on 40's with a body lift and a whole lot more
DTR's Donation page
RIP DTR Ron
you are missed and will live on through your great video contribution to the DIY community
Zmann is offline
post #27 of 33 (permalink) Old 12-29-2016, 03:06 PM Thread Starter
Turd-250's Avatar
i think i'm going to figure out which body mount is causing all the ruckus, and then pull the bolt & wachers out. then i'll go ahead and build that little form out of something or another and squeeze some silicone in there & see how well it does! i just can't see paying so much for oem, and i don't want the hard-ass urethane ones! though i may go with them since they are like $100 a set if the silicone trick doesn't work
Turd-250 is offline
post #28 of 33 (permalink) Old 01-08-2017, 02:28 PM
I have urethane in my F350 dually, I have zero complaints. It's a transport truck
PhilStubbs is offline
post #29 of 33 (permalink) Old 01-08-2017, 06:35 PM Thread Starter
Turd-250's Avatar
thank you! any change in the ride that was better/worse????
Turd-250 is offline
post #30 of 33 (permalink) Old 01-09-2017, 01:40 AM
Hard to say if it's worse. I put F450 rear springs on my F350 for the added weight, but it doesn't ride bad. I could daily it with no trailer without any issue
Human Verification
