Just got finished with oil cooler change and everything went well other than a antifreeze leak on one of my EGR delete gaskets. On the section of the delete kit that replaces were the cooler would have been there is a shaft with an o-ring seal and then a block off plate with an O ring seal on the bottom side of the intake. one of the two gasket is leaking and I'm not sure which so I would just assume replace both. However I cannot find anywhere that sells just replacement gaskets. Does anyone know where I might be able to get just gaskets for an EGR delete kit?
