5R MODIFIED DIRECT CLUTCH SOLENOID INFO - Page 10 - PowerStrokeNation : Ford Powerstroke Diesel Forum
 10Likes
post #91 of 92 (permalink) Old 10-21-2016, 01:33 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: 5R MODIFIED DIRECT CLUTCH SOLENOID INFO
The reason for the occasional flare is rooted in the design of the transmission. The 3-5 shift is made by releasing the intermediate clutch while simultaneously applying the direct clutch. The release and apply have to both finish within 0.030 of a second of each other or the shift is going to suck. The adaptive software continuously updates the pressure for the shift to try to keep it consistent, but it's a losing cause. Very, very small changes from one shift to another can affect the time a clutch needs, causing the flare. In short, the trans design is too sensitive.
Mark
Mark Kovalsky is offline
post #92 of 92 (permalink) Old Yesterday, 03:52 AM
Bump for new info
BYBYLS1 is offline
Human Verification
