DieselSite HPODS test results. - Page 3 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #21 of 25 (permalink) Old 02-17-2014, 04:40 AM
SledDogg's Avatar
Re: DieselSite HPODS test results.
What is the current state of testing?
06' F250 Harley Davidson Edition(Factory 2.5" lift)CCSB-blue sping kit, ARP, gaskets up, Driven Diesel Coolant Return, Sinister Diesel Coolant filter, Rotella ELC, SCT X4, 55gal Aluminum Fuel tank, B & W turnover. ...Hauling New RV's daily.
02' F250 687,000 miles towing...traded to friend for a boat
SledDogg is offline
post #22 of 25 (permalink) Old 02-23-2014, 01:40 AM
so i have a early 04 what do i do for more oil pressure? since i have stock hpop and 205/100 injectors?
2004 f-250 ccsb,RCD 68mm powermax, 205/100 warren injectors, airdog 2, regulated return/fuel bowl delete,egr delete, banks intercooler, banks ram air intake, banks intake manifold, 4'' exhuast,sct hand held,studded, ams oil oil bypass, coolent filter, 6 inch fabtec lift ,37x13.50x18 toyos
Speedinpolaris is offline
post #23 of 25 (permalink) Old 02-23-2014, 03:07 PM
'05 Excursion
Term3's Avatar
Excursion's all got the older style pump as a carryover from '04. Ford seemed to use the Excursion as a way to use up old parts as some also had the smaller water pump and some later builds had the larger 100mm water pump. Plus they don't have the Dana 60 front axle like the pickups have.
Sent from AutoGuide.com App
Term3 is offline
post #24 of 25 (permalink) Old 04-29-2014, 03:53 PM
I just installed my High Volume HPOP but I have a 2003 6.0 :-(
Waiting on you to come out with a kit for me Bill !!! I'll buy it when you do.
Arrondewerff@gmail.com is offline
post #25 of 25 (permalink) Old 05-02-2014, 12:15 PM
SledDogg's Avatar
I posted over 2.5 months ago.......still no reply!!!
SledDogg is offline
Human Verification
  LinkBacks (?)
LinkBack to this Thread: http://www.powerstrokenation.com/forums/11-6-0l-power-stroke-aftermarket-performance/142561-dieselsite-hpods-test-results.html
Posted By For Type Date
Jay's Build Thread - Page 14 - Ford Powerstroke Diesel Forum This thread Refback 11-15-2015 07:49 AM
