06 F350 6.0 Upgrade suggestions - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 01-19-2012, 11:41 PM Thread Starter
I just bought my first 6.0 and was wondering where to start to upgrade it. It's an 06 F350 with 56,000 miles and is stock now. All suggestions would be great, thanks.
Skpph is offline
post #2 of 6 (permalink) Old 01-20-2012, 12:40 AM
I Love Work'N On Hot Rods
windrunner408's Avatar
Re: 06 F350 6.0 Upgrade suggestions
Maintenance. Start there. Change the oil and oil filters. Change the fuel filters. Flush the coolant sytem and install a coolant filter. Change the transmission fluid and filters. Do at least the tranny, oil, and fuel all at once if you can so you have a base line. Next get something to monitor what's going on under the hood, whether it be gauges, some sort of monitor, or both. I recommend an Edge Insight CTS monitor (not to be confused with the Evolution CTS, which is a tuner and monitor combo. This is JUST a monitor.). It is kind of expensive but is WELL worth it IMO and I feel it is one of the best upgrades I have done to my truck.
Ok get these things done first and then look for adding power. The importance of getting this maintenance accomplished first is to set a base line for future maintenance and to get the truck into a known condition. The importance of monitoring your motor is so you can see when you have a problem and how future mods affect your parameters. Adding power is only going to expose and add stress to any flaw or defect that may be in the truck so it is best to see if they can be identified before adding power as this will help minimize catastrophic failure and further damage. Hope this helps.
Nate
windrunner408 is offline
post #3 of 6 (permalink) Old 01-20-2012, 03:32 PM
It's about Maintenance and try and get an Oasis Report go to Ford with the Vin number this will tell you if it has been a problem child and what if anything has been fixed. As stated gauges and a coolant filter, flush and ELC coolant do you have warranty because Ford does not like the coolant filter and ELC coolant they like to sell egr coolers and oil coolers Run cetane boost in the fuel i use the Ford stuff and once a week drive it like you stole it to keep the egr valve and turbo clean and working they are not grocery getters that will kill them and a fuel pressure gauge because under 45lbs at WOT kills injectors and over 70-75lbs may blow injector o-rings.
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS-Expandable Pyro
AutoMeter Fuel Pressure Gauge
Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC-coolant Filter
pulling 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
EGT,Boost,Trans
2 Stroker is offline
post #4 of 6 (permalink) Old 01-21-2012, 10:34 PM
The Younger
It really depends on what ganna do with it. like wildrunner408 said keep up with the maintenance and keep it running healthy. But it all depends on what kind of power you want to make and if you tow with it or its a dd..
A Special thanks to Smeding Diesel
ΛXA
Bensmeding is offline
post #5 of 6 (permalink) Old 01-21-2012, 10:46 PM
I am only suggesting to start with the maintenance to get the needed stuff done first. Then look at adding power.
Aside from maintenance and monitoring devices/gauges, it really comes down to what the goals for the truck will be. He will almost certainly need/want an exhaust at some point and this can help him get a little better fuel economy in some cases as well.
I just recommend that he takes some time, reads for a little while, asks some questions, formulate a plan for the truck with things that will work and be reliable. Getting the goals properly identified will go along way with ensuring his money goes out in the right direction the first time. JMO.
Nate
post #6 of 6 (permalink) Old 01-22-2012, 12:36 PM
jhunter14's Avatar
You can check out my signature and look what I've done so far... I did all maintenance first like everyone has said.. And have started some precautionary measures that I feel are good to do before tuning power... I have an egr kit waiting on my kitchen table and am still going to order the oil cooler rebuild while I will be in there. But Im not doing an egr delete without an sct because I don't want the cel... Head studs will come in time when funding is available...
Im just trying to give you a comparison considering my truck has low miles as well. (55,000)
Hope that helped at all
2006 F-250 XLT 6.0L 4x4 CC Auto, 8X,XXX miles: 6.4 banjos, RR blue spring, ARP's, EGR delete, STC update, digital FP gauge, SCT Livewire TS, coolant filter, S&B CAI, CFM Smallmouth, 5" straight pipe with 8" tip. Updated turbo feed/drain.
jhunter14 is offline
Human Verification
