Bent pushrods. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 54 (permalink) Old 10-19-2011, 04:34 AM Thread Starter
Dieselboy740's Avatar
Bent pushrods.
#2 cyl. Wtf. Not even running it hard at all.
97 F-250hd d60 swap w/e-locker, shortened wheelbase, 37"s on double beadlocks, oba, 12k winch
1980 300sd Hy35, 3.5"exh, intercooled, Alda removed, pump turned up, 12" front brakes, lowered, bilstiens
2010 fe180 Mitsubishi fuso work truck, 3500lb crane, air comp, bobcat 250 welder, oil tanks
Dieselboy740 is offline
post #2 of 54 (permalink) Old 10-19-2011, 04:39 AM
Stroke it B!tch
fordboy11's Avatar
Re: Bent pushrods.
Holy chit yea something doesn't look right in that picture.
78 F-150 300 straight 6, 3 on the tree
03 F-250 6.0 Play toy
06 F-250 6.0 (general nightmare) 2.5 pulling truck
12 F-350 6.7 Tow rig
Gotta pay to play son!
Originally Posted by F-250-Owner View Post
I know you said you wouldnt turn it up..... but come on.... its like saying "I promise I will only stick the tip in" never happens like that
fordboy11 is offline
post #3 of 54 (permalink) Old 10-19-2011, 04:55 AM
Re: Bent pushrods.
What caused that?
2003 7.3 CCSB
PHP Chip, Full Force Stage 2's, 38R, Tymar, ISSPRO EV2 Boost/Pyro/Tranny, Diamond Eye Duals 4"
Skew12 is offline
post #4 of 54 (permalink) Old 10-19-2011, 05:03 AM Thread Starter
Re: Bent pushrods.
Originally Posted by Skew12 View Post
What caused that?
Thats what im trying to figure out.
It's been running fine. Till yesterday and it started missing. Right down the street from home. Turned around and went home. Diagnosed it as cyl 2 and pulled valve cover expecting to have to change a injector and herro
post #5 of 54 (permalink) Old 10-19-2011, 05:05 AM
Re: Bent pushrods.
Damn. Sounds like it'll get a little interesting. Good luck
2003 7.3 CCSB
Skew12 is offline
post #6 of 54 (permalink) Old 10-19-2011, 05:42 AM
Re: Bent pushrods.
Valve to piston is the first thing that comes to mind.
skippy is offline
post #7 of 54 (permalink) Old 10-19-2011, 06:32 AM Thread Starter
Re: Bent pushrods.
Trying to figure out how much elites machine shop took off the heads when it was there.
"a little" isnt a good measurement imo.
Its been running for 15k since the headgaskets were done. Done plenty of hard towing and hard driving with the stock program.
03 truck with a 05 motor
It has h11 studs, black onix headgaskets, powermax, 54v ficm, 190cc hybrids 8 hole, reg return system, fs2500, snow performance w/m, coolant filter, full egr/ cooler delete, 3.5"dp, 5" full, afe, full gauges, etc....
post #8 of 54 (permalink) Old 10-19-2011, 06:59 AM
04 hotrod's Avatar
Re: Bent pushrods.
if its been running for 15k since the work i dont think thats it. i have seen (only once) in the 6.0l on a compleatly stock engine a badly worn cam lobe cause valve to piston contact. but i dont know for sure. best of luck on your hunt.
04 hotrod is offline
post #9 of 54 (permalink) Old 10-19-2011, 07:09 AM Thread Starter
Re: Bent pushrods.
That's what I was thinking. Going to pick up some push rods tomorrow a spin it by hand to see what we get.
post #10 of 54 (permalink) Old 10-19-2011, 03:25 PM
I Love Work'N On Hot Rods
windrunner408's Avatar
Re: Bent pushrods.
I would say that it is either a worn camshaft or a collapsed lifter.
Nate
windrunner408 is offline
Human Verification
