ICP pressures, IPR, lower boost numbers - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 09-18-2011, 01:31 AM Thread Starter
injected79's Avatar
Well im going to try and make this long story a little shorter. So here it goes, My truck is an 05 6.0 basically stock other than 58v ficm, CAI, 5" exhaust, and matts srl tune. Last week i pulled the tuner off the truck because i was going to try a different tune, well as of a few days ago i went ahead and put the srl tune back on. Had to make a couple trips to southern ohio, and on the second trip down i noticed the truck seemed like it was lacking a little power not much just noticable to me. So i got into a few times and noticed i was only seeing around 20-21 psi of boost. and as of last month i was seeing 27-28 psi. My first thought was possible low fuel pressure. I dont gauges for it yet, i just ordered them friday. So i dont know exact fuel pressure.
Next, i plugged the AE into the truck and took it for a cruise and at WOT icp pressure was only seeing 2000-2100 psi, and ICP desired was right there with it. The IPR at WOT was showing around 88% i beleive. So the ICP numbers seem low to me. SHouldnt it be reading over 3000 psi?
Any thoughts to if it would be fuel pressure or a ICP issue or where do you guys feel i should be looking.
Thanks Ahead of time
Sold puller-1997 f-350 12 valve 913 p-pump, big charger, big fuel, SBC, and so on
Puller-1979 Ford S/B, 60 front, 10.25 rear, 5.13 gears, ockers, 503 BBF, C6 with 2500 stall
DD-2005 F-250 c/c s/b 6.0L lariat, 6" lift, 35"m/t's, 18x12's, 58v ficm, gearhead tuned, 6.4 banjo's, raptor fuel system, 5" exhaust and a CAI
**No Non-sponsor Links**
injected79 is offline
post #2 of 7 (permalink) Old 09-18-2011, 03:49 AM
NSTY 6OH
Dangyo's Avatar
Re: ICP pressures, IPR, lower boost numbers
I know on my 2006 6.0 with erics xrace tune, WOT I only see about 1500 ICP. I contacted eric about it and he told me thats how HE writes his tunes. He told me for a piece of mind even though he already told me it's perfectly fine, to load up my factory tune and take it for a spin. I did at and with the "stock" tune loaded into my truck, anything past about half throttle, I see roughly 3900psi ICP. Contact matt and see how he writes his tunes. It may very well be in the tune like mine is.
2006 FORD F-250 FX4 6.O REGULAR CAB
Built motor/studded/fuel system/tons of bolt ons/exterior mods/lots of gauges/bottle fed/etc
Tuned by Matt Robinson of Gearhead Automotive Performance
Dangyo is offline
post #3 of 7 (permalink) Old 09-18-2011, 04:13 AM Thread Starter
injected79's Avatar
so would you be thinking more along the lines of low fuel pressure to cause the boost lost?
post #4 of 7 (permalink) Old 09-18-2011, 04:38 AM
Snake Oil Salesman
mattr66's Avatar
You have to look at ICP voltage with my tune..... the pressure you are seeing isn't right. you should be holding 4.6 or slightly more volts at WOT.
Matt Robinson
Originally Posted by PSDPlayer View Post
If you have nozzles that were Extrude honed over and over and over again. It will look like a porn stars ass.hole where the pintle is supposed to seal.
mattr66 is offline
post #5 of 7 (permalink) Old 09-18-2011, 04:08 PM Thread Starter
injected79's Avatar
Thanks matt i will check that out later today
post #6 of 7 (permalink) Old 09-18-2011, 06:12 PM Thread Starter
injected79's Avatar
I just took the truck for a run, checking icp voltage. At an idle it stays around .77 - .85 volts, at wide open throttle i seen it as high has 4.77 volts but fluxuated from 4.25 to the 4.77. Seemed to keep a little more constant at 4.4 to 4.6 volts during the run.
post #7 of 7 (permalink) Old 09-20-2011, 11:03 PM
Snake Oil Salesman
mattr66's Avatar
all is well in the world then.....
Matt Robinson
mattr66 is offline
Human Verification
