not warming up - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 04-14-2011, 03:44 PM Thread Starter
solrac06's Avatar
Unhappy not warming up
truck is taking forever to warm up have to wait atleast 10 to 15 minutes at a time just to be able to leave in the morning. working in wyoming right now and it is even worst up here my truck is an '06 with 145,000 miles i take good care of her but it is getting ridiculous.
solrac06 is offline
post #2 of 11 (permalink) Old 04-14-2011, 03:49 PM
PETE ENGR PSD
Re: not warming up
What do you mean by warming up? No heat or it continues to miss?
KEVIN
2006 F-350 Kingranch 79,XXX
TAMU_PSD is offline
post #3 of 11 (permalink) Old 04-14-2011, 05:21 PM
Diffrent Strokes
orrwhat's Avatar
Re: not warming up
If the engine is taking forever to warm up then the thermostat is stuck in the open position and needs to be replaced.
2006 F-250 CC SB 4X4, all stock with egr system for now.
orrwhat is offline
post #4 of 11 (permalink) Old 04-14-2011, 10:35 PM Thread Starter
solrac06's Avatar
Re: not warming up
i meant no heat it just stays cold until i get tired and just drive off it will hesitate for a while but she will eventually get hot enough to run at temp. will defenitly change the thermostat as soon as possible thanks fellas
solrac06 is offline
post #5 of 11 (permalink) Old 04-14-2011, 11:48 PM
Administrator
Zmann's Avatar
Re: not warming up
you really need to input more info !
what is outside temps?
is this a new problem?
and any other items you can think off ??
because We don't have one of these
lol
DTR's Donation page
RIP DTR Ron
you are missed and will live on through your great video contribution to the DIY community
Zmann is offline
post #6 of 11 (permalink) Old 04-15-2011, 05:03 AM
ddbck's Avatar
Re: not warming up
Yes try the t-stat, and more info. I also live in Wyoming 4-6 min warm up has always been plenty.
2007 F250 XLT
6.0 POWERSTROKE
AFE COLD AIR INTAKE
MAGNA FLOW EXHAUST
6" FABTECH DIRT LOGIC 4.0
37/13.5/20 TOYO OPEN COUNTRY
AMP RESEARCH POWER STEP
SCT X3 TUNES BY GEARHEAD & IDP
ddbck is offline
post #7 of 11 (permalink) Old 04-15-2011, 07:17 AM
Dieselboy740's Avatar
Re: not warming up
Plug it in on a timer so you don't have to wait as long? Lol
Sounds like a thermostat that is going bad. These have a "failsafe" that when they fail they are "supposed" to stick open not closed. That would cause you to have longer warm up time than usual.
97 F-250hd d60 swap w/e-locker, shortened wheelbase, 37"s on double beadlocks, oba, 12k winch
1980 300sd Hy35, 3.5"exh, intercooled, Alda removed, pump turned up, 12" front brakes, lowered, bilstiens
2010 fe180 Mitsubishi fuso work truck, 3500lb crane, air comp, bobcat 250 welder, oil tanks
Dieselboy740 is offline
post #8 of 11 (permalink) Old 04-16-2011, 11:01 AM Thread Starter
solrac06's Avatar
Re: not warming up
Changed out tstat last night hope it works
BTW it has been cold up here avereging at about 32* a night
This has been happening for about 3months now and I can't
stand it anymore. I thought it was just because it was cold but
I see other 6.0's warming right up and leaving me in the parking lot.
solrac06 is offline
post #9 of 11 (permalink) Old 04-17-2011, 07:15 AM Thread Starter
solrac06's Avatar
Re: not warming up
still not heating up after tstat change but read in other posts that fan should not come on until it needs to my fan is always on how do i fix
solrac06 is offline
post #10 of 11 (permalink) Old 04-17-2011, 12:29 PM
Re: not warming up
Do you have any aftermarket mods?
Mark
bismic1 is offline
Human Verification
