Loses Power, quits when warm! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 03-07-2011, 08:12 PM Thread Starter
Chummin Along!
I know I know I have searched and read all there is about the 6.0 losing power. My EGR Cooler is bad I know that and leaks some, not a whole lot, but after a few weeks it is down on coolant.
Well just saturday I was coming home, bout 35 mins and probably 10 mins from home, it lost all power and when I came upon turning into the driveway it quit. Wouldn't restart until probably an hour or so later. And now, within 10-15 minutes of driving it gets warm and loses all power and wants to quit. It doesn't smoke after losing power and starts up just fine when cold.
So, HPOP, fuel filters, FICM? I have the EGR delete kit but was waiting for the weather to break before I put it in. I am going to pick up some filters tomorrow. I saw swamps post on checking the FICM, how about the HPOP? Is there any info out there on how to check it?
Thanks,
-Matt
Oh, the truck is an 03, 6.0 auto. Has a bullydog chip that I don't think works, an a jegs exhaust, K&N filter setup, has 280k on it. I bought it the way it is with what was spose to be bad head gaskets but figured it was just EGR considering it has run fine for the last 5k miles I have put on it.
99 with an updated face and a lil more power under the hood....24V Cummins twin turbo and ZF-6
slvr98svt is offline
post #2 of 5 (permalink) Old 03-07-2011, 10:44 PM
I Just Break Stuff
Re: Loses Power, quits when warm!
1 question, why would you drive a truck that possibly has gasket/leaky egr cooler issues?????? Asking for a catastrophic failure.
Moving on, what test have you run on it?
Checked ficm voltage??
Icp???
Any blowby out the oil fill tube?
Using more coolant?
EOT vs ECT??
Cranks when it's cold, just not hot??
06 f250 cc Lariat
4 inch Turbo Back
EGR Delete by FCDP
SCT w/Gearhead tunes
Lowered 3 Inches
ARPs
Barder stage 3
Warren Diesel 190/100s
Fluidampr
No Limit intake
Full billet Tranny
6.4 Banjos
AD II
CTS Monitor
GS Elite Gauges
Zex Nitrous
IPR Oil Cooler Relocation kit
irontx25 is offline
post #3 of 5 (permalink) Old 03-08-2011, 12:04 AM Thread Starter
Chummin Along!
Mainly I drive it still because I haven't had the time to pull it into my garage and do it. I drive a round trip of 5.5 miles from my house to my garage other than that it normally doesn't get driven unless I have to go somewhere when I don't have any other vehicles available. So, maybe once a week it sees anything further 20-30 miles. But I know that is no excuse just been really busy lately!
Onward,
It barely uses coolant, from "max" to "min" on the reservoir takes...maybe 3 weeks or more.
FICM I am going to check tomorrow
No blow by out the oil fill tube.
Starts right up when cold, cranks after it gets to temp and then shut off
How do you check the ICP?
And also I am thinking you guys have temp gauges for your coolant and engine oil in pods maybe? Only thing this has is an egt gauge.
I just bought it on a whim before winter started as my DD went down with head gasket issues when pushing it a little hard at 75psi. So I didnt want to dump a ton of money into this as I was looking to get rid of it soon as the weather broke and I fixed the EGR deal.
post #4 of 5 (permalink) Old 03-08-2011, 12:08 AM
I Just Break Stuff
Need to get a scanner. AE, scan tool, snap on solus, ids... Something to get some live data.
06 f250 cc Lariat
4 inch Turbo Back
EGR Delete by FCDP
Lowered 3 Inches
ARPs
Barder stage 3
Fluidampr
No Limit intake
Full billet Tranny
6.4 Banjos
AD II
CTS Monitor
GS Elite Gauges
Zex Nitrous
irontx25 is offline
post #5 of 5 (permalink) Old 03-08-2011, 05:42 AM
Marc's Avatar
Check your ICP as was stated above. Sounds to me like your HPOP is done. Ive seen this many times and i bet if you pull your IPR valve out it also has a ton of metal contamination on the screen or has a hole in the screen.
NHRDA Region 2 Race Director
Marc is offline
Human Verification
