Scangauge II FICM - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 346 (permalink) Old 02-23-2011, 12:50 PM Thread Starter
DieselStroke's Avatar
Question Scangauge II FICM
Ok so here it goes, with the x-gauge people have been able to make x-gauge codes that are not listed by manufacture, this is done through trial and error of the PID from Ford in order to program it in. It would be amazing if we could read FICM without having to rip it apart or purchase AE. However my question is what is the PID of FICM_M?
2004 F-350 SC LB 4x4
6spd manual transmission
Edge Juice w/attitude
Scangauge II by Linear Logic
Straight pipe exhaust
Westin Bull Bar
Lights
DieselStroke is offline
post #2 of 346 (permalink) Old 02-24-2011, 01:48 PM Thread Starter
Re: Scangauge II FICM
Bump, No-one knows the Hex number for the PID? I know the name of the PID, however need the hex number in order to try and write it in scangauge as a monitor.
FICM MPWR PID
Westin Bull Bar
Lights
post #3 of 346 (permalink) Old 02-25-2011, 05:28 AM Thread Starter
Ok so working with Linear Logic and a little trial and error we were able to pull the below readings from the PCM using the scangauge ii with X-Gauge:
FICM Power (12 Volts)
FICM Logic Power (12 Volts)
FICM Main Power (48 Volts)
I am waiting for a final confirmation from Liner Logic for the math calculations but i am testing this on my truck right now and everything checks out, curious to how many people are interested in the X-Gauge code for the above readings??? I will send a follow up post with confirmation from Linear Logic and possibly the codes if people want them to add to their display
Thanks,
Patrick
Westin Bull Bar
Lights
post #4 of 346 (permalink) Old 02-25-2011, 01:19 PM
Post them up
TT
Zoodad mod, high idle mod, blue winshield washer fluid, cat delete mod, tinted windows
jonnysteals is offline
post #5 of 346 (permalink) Old 02-25-2011, 01:34 PM Thread Starter
Here is what i have right now, curious to see what other people are getting for readings, waiting for confirmation on Linear Logic on the math but these should be correct!
FICM Vehicle Power (Volts) (Should be 12 Volts)
TXD: 07E02209CE
RXF: 0462450906CE
RXD: 3010
MTH: 0064010000000
NAM: FVP
FICM Logic Power (Volts) (Should be 12 volts)
TXD: 07E02209CF
RXF: 0462450906CF
RXD: 3010
MTH: 0064010000000
NAM: FLP
FICM Main Power (Volts) (Should be 47-48)
TXD: 07E02209D0
RXF: 0462450906D0
RXD: 3010
MTH: 0064010000000
NAM: FMP
Everyone post back if these work for you and if so will see if i can have Linear Logic put in on their website.
Westin Bull Bar
Lights
post #6 of 346 (permalink) Old 02-25-2011, 09:25 PM Thread Starter
Bump,
Someone else please test these gauges on the x-gauge to confirm if they are also working for you....
Thanks
Patrick
Westin Bull Bar
Lights
post #7 of 346 (permalink) Old 02-26-2011, 01:49 PM Thread Starter
Well its saturday, someone else please test the above codes today to see what you get!!!
Westin Bull Bar
Lights
post #8 of 346 (permalink) Old 02-26-2011, 02:00 PM
Bowhunting Freak!
BigDeal21's Avatar
Mines in the mail. As soon as I get it hooked up next week il try it and let ya know how it works.
BigDeal21 is offline
post #9 of 346 (permalink) Old 02-26-2011, 03:16 PM Thread Starter
awesome, here is also the VGT Turbo Cycle
VGT Duty Cycle (%)
TXD: 07E022096D
RXF: 04620509066D
RXD: 3010
MTH: 00647FFF0000
NAM: VGT
Westin Bull Bar
Lights
post #10 of 346 (permalink) Old 02-28-2011, 01:19 PM
Send a message via MSN to jorlee Send a message via Yahoo to jorlee
Just had time to put in the FICM Main power. Got readings of 48.5, 48.0 47.5, and lowest of 45.5 on a 0-65 run.
I'll try to get the others entered in today, and report back.
2006 F250 6.0 XLT 4x4
Jordan
jorlee is offline
Human Verification
  LinkBacks (?)
LinkBack to this Thread: http://www.powerstrokenation.com/forums/10-6-0l-power-stroke-technical-info/93317-scangauge-ii-ficm.html
Posted By For Type Date
Scangauge II EOT Codes - Ford Truck Enthusiasts Forums This thread Refback 10-30-2015 01:11 PM
